drag setup?
drag setup?
building my first street strip car and need some advice on what to buy to help the 60ft time. the cars a mild big block 425 hp and 475 torque 400th, 2400 stall posi and slicks but the rest is stock what do i want to do first torque arm,air bags,shocks,lower control arms panhard.south side machine setup theres so many choices and i dont have the money to experiment till i find a setup that works. i dont have a time on it now (not done) thanks.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Every improvement you do the the suspension will help. The goal is to remove all the excess movement in the suspension. When rubber bushings and stamped steel parts flex, it's lost energy. I still have a stock front end except for the removal of the front sway bar. The rear has everything done. Spohn torque arm, Herb Adams lower control arms and panhard bar, air bags in the springs, sub frame connectors and still have stock rear shocks.
Change it all if you want to race the car.
Stephen's racing page
87 IROC-Z Pro ET Bracket Race Car and knocking on the SuperPro ET class
383 stroker (carbed) with double hump cast iron heads and pump gas
Best ET on a time slip: 11.857
Best corrected ET: 11.163
Best MPH on a time slip: 117.87
Best corrected MPH: 126.10
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
Best 60 foot: 1.662
