Help me figure out this oil leak >>>
Old Aug 1, 2000 | 03:34 PM
dnovotny's Avatar
When installing my Spohn torque arm, I noticed some oil around the rear of the torque arm where the two bolts attach to the rear axle, and also some oil on the bottom of the car in the same area. I looked at the torque arm a couple of weeks later, and see some oil building up again in the rear area. Its not coming from the rear cover of the axle, so where is it coming from?
Thanks, Dave
Old Aug 1, 2000 | 03:38 PM
85ZZ4TPI's Avatar
Pinion seal?
Old Aug 1, 2000 | 08:04 PM
dnovotny's Avatar
First, what would cause this, since I only have 83K miles. An out of balance driveshaft? Second, how easy is it to fix. Or should I use this an excuse to swap in a 12-bolt.
Thanks, Dave '91 T/A
1986Z28OWNER
Dec 13, 2015 10:19 PM
Navy8125
Aug 21, 2015 09:32 AM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
drathaar907
Aug 6, 2015 04:20 PM
