Planning a Minirammed 383: Insight needed.
Old Jul 31, 2000 | 08:26 PM
ws6transam's Avatar
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
Okay experts,
I just put a deposit on a fully ported Miniram with 58mm throttle body and balanced 30 lb injectors.
I have in my garage, on the engine stand, a 4-bolt main 383 block with 5.565" con rods, cast crank, and forged pistons. I also have a set of roller retrofit lifters for the engine, but have not yet picked out the EFI computer, cam, or cylinder heads.
How would I best utilize the miniram with said shortblock? This will back up a 700R4, be normally aspirated, and will rev to 6250 RPM. Would AFR 190's be the best choice? How about cam? .540 inches of lift, 230 degrees duration @ .050" ??
Should I go FP performance, so that I can individualy trim each injector's pulse width?
What do you think?
Daniel Burk
http://www.isthq.com/~dan/fcar.html
'84 Trans Am WS6/L69
KB SFC, Moser axles, Torsen Diff. PST suspension, Braided stainless brake lines,
5-point racing harness, Koni struts, 11-inch rear disks,Spohn Adj. torque arm,
Ported 305 heads w/1.94"intake valves, Comp Cams XE262H, Griffen alum. radiator,
Speed-sensitive steering conversion, underdrive pulleys, Crane Hi-6 & more. 1.05g skidpad verified.
Old Jul 31, 2000 | 08:46 PM
GMI FAST's Avatar
Sounds fine. I don't think you need any insight...Also sounds familiar, except for my Vortech.
1989 Formula 350, 10.5:1 383", TFS heads, Comp Cams blower grind, TPIS Mini-Ram, BBK 58mm throttle body, Vortech S-trim 15 psi, DFI, 42# injectors, S/X fuel system, MSD ignition, SLP 1.75" headers, Flowmaster exhaust, MW Racehouse 700R4, Currie 9" w/3.50 gears, Jeg's sfc's, Jeg's lca's, S&W 8-point rollbar, lookin' stock street racer...
Best ET: 10.796 @ 125.8 on 16" Sportsmans...
Old Aug 1, 2000 | 12:50 AM
Dan87IROC-Z's Avatar
I am building the same motor, so lets make a deal and send eachother all the info we get. As for heads, I have heard that the Brodiz track heads are a better choice than the AFRs are.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Current Mods: Edelbrock TES Headers, Hooker Cat-Back System, Performance Resource Chip, 160* Thermostat, Accel 8.8mm Ignition Wires, K&N high flow air filters, gutted air box, gutted MAF sensor, Throttle Body Coolant By-Pass, Homemade Ram-Air, Falken ZIEX Z-Rated Tires.
1/4 mile times without chip:
Best ET: 15.7 @ 89MPH
Best Corrected ET: 14.5 @ 96MPH
Old Aug 1, 2000 | 05:48 AM
ws6transam's Avatar
Why do you think the Brodix are a better cylinder head? Combustion chamber design? out-of-the-box flow? Price? What's better? Perhaps this is worth taking to a different thread.
My 383 engine project is going to take about 18 months to complete. Expect it to start running in the spring of 2002. I still need to tear down the shortblock, magnaflux everything, and have the reciprocating assembly inspected shot peened, and balanced. Since the bores still have crosshatch from the last rebuild, it looks like a relatively low-mileage 383 conversion so it might not cost much to finish. I'm concerned about using a cast crank & the short 400 rods at 6250 RPM and 425 horsepower... Anyone have any experience?
Old Aug 1, 2000 | 07:48 AM
Box of Rocks's Avatar
ws,
It's probably wise to be concerned about the 400 rods going to 6250 RPM. I think the crank is marginal at that RPM too. Have you considered the GM powdered metal 5.7 rods ?
I've seen them advertised as low as $146 for eight. That is very cheap insurance, especially since they're rated to 450 HP. Also, the SCAT crank (new) is only $269 from Jegs. So, for an additional $415, you can build a reliable 6,250 RPM motor.
You've got forged pistons, right?
Good luck.
BOR
Old Aug 1, 2000 | 01:50 PM
82 Z's Avatar
I've got brand new ported Track 1 heads for sale cheap, if interested.
Old Aug 1, 2000 | 08:57 PM
ws6transam's Avatar
The pistons are stamped with a number: 2244P. I'm hoping that these are forged! If not, then you are probably right: Replace the reciprocating assembly with a SCAT crank, GM "pink" PM rods, and forged pistons.
I might just place this assembly into a different block (I have two) and sell it as a stroker torque TPI engine.
As for the Track 1 heads, sorry! I have a monthly budget that I (unsuccessfully) try to stay in. Currently, I won't be able to get the heads until mid-2001. I'm going to budget $1500 for the heads.
[This message has been edited by ws6transam (edited August 01, 2000).]
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
bschmale66853
Sep 30, 2015 08:11 PM
Zell1luk
Sep 29, 2015 10:36 AM
efiguy
Sep 27, 2015 01:30 PM
