water pump or radiator?
Old May 20, 2003 | 05:37 PM
e-man's Avatar
Car: 89 formula
Engine: 383
Which would have more effect on dropping temps a stewart high flow pump or a aluminum radiator? I plan on doing both but dont have the funds right now.
Old May 20, 2003 | 07:56 PM
Tom84L69's Avatar
Car: 84 Z28
Engine: L69: cam and porting
Transmission: T5, 3.73 rear
i say radiator, but i have no "proof"
I think all that a high flow pump would do is flow the hot water around faster while an aluminum rad will actually cool more efficiently.
Old May 21, 2003 | 09:46 AM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
aren't thirdgen radiators aluminum already? Well, mine's aluminum with the plastic tanks. I would say go with the aftermarket radiator as well.
Old May 21, 2003 | 10:17 AM
ede's Avatar
ede
i'd make sure i didn't have any problems in the system now before i went throwing dollars and parts at it.
Old May 21, 2003 | 03:00 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Yup, I went thru that a while back. Had cooling problems, so I went out and bought an aluminum radiator to help, but it didn't, it was because there was another problem. However, the radiator would be needed now, so it's all ok.
Old May 21, 2003 | 06:09 PM
e-man's Avatar
Car: 89 formula
Engine: 383
I have a copper replacement radiator.Its not that the car over heats Its just since putting in the new motor the temps rise in traffic and they dont go back down after moving awhile like they use to with my old motor.I have the fans on 24/7 and I bleed/purged the air out of the system.What else is there to check?
Old May 21, 2003 | 07:28 PM
Tom84L69's Avatar
Car: 84 Z28
you can replace the thermostat if yours is old or the wrong temperature.
Old May 22, 2003 | 04:16 AM
e-man's Avatar
Car: 89 formula
Engine: 383
Its a 160 T-stat and it works.Its just that the new motor runs a little hotter and I would like it the way it was before.
eightsixseven
Dec 16, 2024 01:50 PM
Chuck84TA
Jul 15, 2016 09:05 PM
Dialed_In
Aug 20, 2015 01:45 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
