what do i need for my new engine?
Old Sep 10, 2000 | 09:54 PM
icommandoi's Avatar
I am thinking of getting the GMPP 350HO Deluxe. It says it is complete, carb - pan. Do i need anything for it besides spark plugs/wires, and i mean anything?
Old Sep 10, 2000 | 11:51 PM
Andy89RS's Avatar
oil?
Old Sep 11, 2000 | 12:28 AM
D_Amlee's Avatar
Car: 89 IROC
Engine: Yes
Transmission: That, too.
gas?
Old Sep 11, 2000 | 12:40 PM
perp's Avatar
Supercharger
Old Sep 11, 2000 | 12:48 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Inadequate information. What year is it, and what's currently in your ride: V-6 or V-8; carb, TBI, or TPI; auto or stick? What are you going to do with it: daily driver, street/strip, race-only?
82 Berlinetta, orig V-6 car. Rescued w/86 LG4/TH700R with all harnesses, sensors, ECM, etc. 3.08 open, cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress.
57 Bel Air, my 1st car. Currently 396 .030 over, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & shift kit, 3.08 10-bolt, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
Old Sep 11, 2000 | 12:55 PM
IROC-ZTWENTYGR8
Guest
Posts: n/a
Supercharger........LOL!!!!!!!!!
Old Sep 11, 2000 | 03:04 PM
daniel dekay's Avatar
Old Sep 11, 2000 | 03:06 PM
LDY's Avatar
LDY
the 502 crate that SDPC offers
Old Sep 11, 2000 | 09:56 PM
icommandoi's Avatar
Ha Ha, seriously though, I think i will need Spark Plugs, Wires, Oil =), Gas =), Engine Mounts, any thing else like a starter or things like that? (I am going from 2.8l to 5.7l)
Old Sep 12, 2000 | 08:02 AM
Hurtin4Hp's Avatar
Car: Transformed 86 Coupe
Engine: 400 sbc
I think it was Car Craft or GM Performance that had an article this month on everything else you need. They had a complete list with part numbers and prices. It seemed pretty complete to me, and actually reminded me of a couple of items that I was missing(like wire looms).
Old Sep 12, 2000 | 01:08 PM
five7kid's Avatar
Well, now you're starting to give info we can use to answer your question.
You'll need new tranny (or flywheel & clutch - you didn't say if you have auto or manual tranny - flex plate comes with the engine), shifter cable if auto, front & rear mounts, all accessory brackets, starter (like you said), battery cables, radiator, fan, hoses, belts, wiring harness (or extensively mod the V-6 harness), fuel pump & lines (or regulator and associated lines to drop the fuel pressure if your V-6 is SPFI), air cleaner, vacuum lines, power steering lines, front springs and swaybar (do the front mounts while you have the lower control arms off to change the springs - best way to get at those engine mount bolts). You'll also have to reroute the front brake line where it goes across the front crossmember. Your current tach also won't be accurate with the V-8.
If you need to maintain emissions legal status, you're in for even more fun. The best way to go about that is with a complete V-8 parts car. And, the carb they give you with the engine won't be emissions legal. I assume that isn't an issue, or you wouldn't consider this swap in the first place.
Even if you don't need to worry about emissions, a donor car would still be worth it to get all these parts.
One other thing you'll need - alternate transportation for a couple of months.
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
