steering column wobbles....how to fix?
Old May 25, 2003 | 11:36 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
ok i have tilt steering and my steering column wobbles right after it tilts and goes to the steering wheel........how would i fix this?
thanks!
Old May 26, 2003 | 07:40 AM
ede's Avatar
ede
do a search and you'll find lot of info and maybe links.
Old May 26, 2003 | 08:59 PM
Damon's Avatar
There's a bolt that loosens up in the GM tilt wheel design. Very common. Gotta dig long way into the column to fix it, it think. Never fixed one myself, though.
Old May 26, 2003 | 10:55 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
yah i searchd the tech articles and sure enough it was there......thanks
btw would i b able to borrow some of those tools from autozone?
and am i in danger by driving it under this condition cuz i probably wont b able to get it done for another week or 2
thanks
Old May 27, 2003 | 08:18 AM
Vader's Avatar
Rumor is that you can "rent" a tool from AutoZone and get your "rent" fee returned when you return the tool intact. The only special tools you should need are a wheel puller and lock plate depressor. They are't likely to have the tool for removing the pivot pins, but it's easy enough to make what you need from a machine screw and nut.
Old May 27, 2003 | 11:27 AM
ede's Avatar
ede
i use a deep 1/4" inverted torx socket from snap on, works way better then a short socket, cost around 10 dollars.
83 Crossfire TA
Jan 3, 2016 01:26 PM
383cam
Sep 9, 2015 06:01 AM
SG91camaro
Sep 5, 2015 10:27 PM
Ian Irvine
Sep 4, 2015 08:08 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
