Is it possible to install the main bearing upside down/backwards??
Old May 26, 2003 | 09:21 PM
ChrisFormula355's Avatar
Car: Junk
Engine: Junk with nitrous
Transmission: Junk with gears
Was just flipping through my chevy overhaul book and noticed the sectino showing bearing failure on new motors that had the main bearing installed upside down blocking the oil hole. I just put my new bottom end together and I really did not pay attention to those holes.............isn't it fool proof??? i thought their were tabs on the bearing that only allowed you to install them a certain way?? **** now I'm worried. They were clevitte 77 bearing.
Old May 26, 2003 | 10:05 PM
Vader's Avatar
Yes, it matters. Oil delivery to the bearing is dependent in the hole position.
That's one of the things I like about the Clevite 77/Gs - they're marked rather clearly:
Attached Thumbnails Is it possible to install the main bearing upside down/backwards??-mainshells.jpg
Old May 26, 2003 | 10:23 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
and the obvious hole in one of the bearings:
Attached Thumbnails Is it possible to install the main bearing upside down/backwards??-rearmainbearing.jpg
Old May 26, 2003 | 11:21 PM
Car: Junk
So the top one won't have a hole?? I'm going to remove just the caps so I don't have to tear down the motor again then.
Old May 26, 2003 | 11:23 PM
mrr23's Avatar
Engine: 360 HSR
the one for the cap will not have a hole. the one for the block will. as you can also see in the pic, the other bearing have a groove in them. those also go in the block. the flat ones go in the caps.
Old May 26, 2003 | 11:35 PM
Car: Junk
Ok thanx, I'll check it out. Won't be able to sleep knowing that my $3K motor has the bearing in backwards!!
Old May 27, 2003 | 12:13 AM
1982z28's Avatar
Car: 1999 Z-28
Transmission: m6
Axle/Gears: stock/3.42
Just out of curiosity--would you get oil pressure if they were in backwards? I would imagine you would know it shortly after start up if this had happened????
Old May 27, 2003 | 05:58 AM
ede's Avatar
ede
yeah you'd get oil preasure. most if not all SBCs read the oil preasure from a passage off the cam/lifter gallies and that oils before the crank does.
anesthes
Mar 10, 2016 10:35 PM
red90IROCls1
Aug 25, 2015 06:56 AM
theurge
Aug 21, 2015 12:46 PM
rsrmoore
Aug 7, 2015 08:44 PM
