engine running hotter than usually does
Old May 29, 2003 | 07:34 PM
SX Stinger's Avatar
Car: 84 Z28 "Holly" (SOLD)
Engine: Carbed 305
Transmission: TH350
okay here's the problem, My engine is running hotter than normal and hotter than it did last year at this time. My coolant is new and the level is correct. My timing is correct also. It is pinging once it get's hot. Today I seperated the radiator from the A/C condensor and the gap between them was full of everything from leaves to plastic. So I thought that might be the problem because it was choking air flow. Well it takes longer for it to get to the pinging stage now and I have more power, but I am still running hot and pinging. Do I need to buy a 160 degree thermostat or what. I have done everything that I can think of.
Thanks Drew
Old May 29, 2003 | 08:14 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
You might want to change your stat for PM. You said the level is okay, how about the water pump? Does the coolant circulate when you look into the radiator? Is there any stuff in the coolant? What are you using for a fan? If it is mechanical have you checked the fan clutch? Just a few thoughts I had. Good luck...
Old Jun 3, 2003 | 07:49 PM
SX Stinger's Avatar
Engine: Carbed 305
Transmission: TH350
I have changed the fan clutch and the water pump with in the last 6 months so they are okay. Coolant was clean. I went out and bought a 160 degree thermostat and so far it seems to be running great .
Thanks Drew
Vintageracer
Jan 10, 2020 05:33 PM
theshackle
Mar 5, 2017 06:37 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
camaroken83
Aug 10, 2015 11:35 AM
