Name That Part!
Old Sep 12, 2000 | 09:11 PM
Abe91Z28's Avatar
Name That Part!
Ok, today after driving around with the "starter fixing tool" (crowbar) i noticed my car was making a rubbing noise. So, i looked all over trying to find the sound and i finally found it. But, i don't know what the name of the part is i asked my friend what it was and he also didn't know. So, i decided to see if u guys could help me. There is a plastic peice that is between the oil pan and the Tranny pan, this plastic is rubbing against whatever is above it and making an annoying sound. If i pull at the plastic it stops. I think when i drove through the puddle (see msg titled "starter questions" about puddle info) it made this plastic peice rub. I'm wondering if anything above this plastic peice could be damaged, and or if its a common part to be "rubbing" against eachother. I am trying to figure out away to fix it. In the meantime any info would be helpful.
Thx again!
-Abe
Old Sep 12, 2000 | 09:19 PM
Allan's Avatar
Car: 1988 IROC-Z
Engine: 5.7L TPI
Axle/Gears: BW 2.77
you mean that torque converter cover thingie? bell-housing cover. i guess. damn i got a case of the dumba$$ too!
Old Sep 12, 2000 | 10:04 PM
Vader's Avatar
Abe,
I wouldn't get too carried away with trying to flex that cover around with the engine running. If the plastic decides to let go, your fingers are going to be right in the torque converter/flex plate - you'll end up typing your next post with your lips.
Stop the engine, remove teh cover bolts, and the cover. Any interference should be apparent on the inside of the plastic. No, the cover is not supposed to touch the flex plate or converter. Yes, it is possible that your "log ride" through the puddle distorted the warm plastic into something it isn't supposed to be. If you can't reshape the cover, get a replacement from your local recycler. $10.00 would be a lot to pay for a used cover, and I'd be surprized if it was that much.
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
Old Sep 12, 2000 | 10:08 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
From Vader..."you'll end up typing your next post with your lips."
ROTFLMAO
Sorry, the visuals were just too funny!!
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am, flowmaster,FRA,Pro Kit,BMR STB, polished calipers.
1986 Chevy 3/4 ton pick up,flowmasters,4.10s,
1981 corvette FOR SALE
1995 ZX6R,Yosh,D207s
GO #3
Old Sep 12, 2000 | 11:16 PM
fb305svs's Avatar
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
yeah the torque converter inspection cover... just yank on it till it streches back out or replace it, nuthin above it would get hurt by it sooo
Steve
88 Firebird Formula- deseased 2/9/99- 305 TPI, SLP 3 inch exhaust, SLP Intake runners, SLP cam, 3.45 BW disc brake posi, WS6, NOS, and all that good stuff, 13.~ sec 1/4 mile- hit by what else!?!? a FORD EXPLORER!!!!!!
86 Firebird, LG4, t-tops, slp 3 inch exhaust, catco cat, and a bunch of new/replaced stuff, open element, soon to come, 2 inch cowl hood, 3.42 posi disc rear from a 4th gen, and hopefully a 6 speed!
My Webpage- Battle of the birds, My own Thirdgen Page, still under construction, http://www.geocities.com/soares711/index.htm
Old Sep 12, 2000 | 11:17 PM
witchdr's Avatar
hahaha I'm with you Engineboy, too funny, man. Anyways, it sounds like you're describing the flywheel cover, in which case Vader is correct, DO NOT SCREW WITH IT WHILE THE ENGINE IS RUNNING!!! Should just be four easy to reach 9/16 bolts and it'll drop right off. You may want to use a degreaser and clean any accumulated oil or road grit that lies in the bottom of it. Good luck.
`85 Z28
Bosch Platinum +4s & a nice stereo
Otherwise stock.
Don't ever be: Found On Road Dead!
Old Sep 14, 2000 | 03:02 AM
812MANY's Avatar
I used to work at a tranny shop....
It's called a dust cover, and they should be 10MM bolts, NOT 9/16ths!
You can actually just leave it off...
Ok, maybe you shouldn't (since you seem to be the type of person that likes to hydroplane through puddles) <grin>
Old Sep 14, 2000 | 07:16 AM
Mike 25th's Avatar
I had the same thing happen with my '91. I bombed through a huge puddle, then heard the same noise. I thought I really messed s!@t up, but I just backed the screws off a little bit and snugged them back up and it was fine. They are right - should be 10mm.
92 Z28 - 5.7 - Black/Grey Leather
Macewen White Faced Guages
SLP T-RAM, 24lb/h Injectors
Accell 52mm Throttle Body
SLP 1 3/4" Headers and Cat Back Sys.
Old Sep 14, 2000 | 10:13 AM
johnyIROC's Avatar
It's the flywheel cover.... and I took mine off about a year ago (not reccomended)... If you bottomed out good enough to dent the plastic flywheel cover, chances are you may have bent the flywheel. What inspired you to crawl under your car while it was running?
johnyIROC 1983 Z28
Silly rustang, 5.0 is way too slow
-87 IROC front clip and ground effects
-Hand pollished Z28 wheels
-Hurst Pro Matic 2 shifter
-Functional hood ducts
-Limo tint all around
-350 stroker coming this winter
Old Sep 14, 2000 | 03:59 PM
witchdr's Avatar
Oops, you're right, 10mm, sorry.
Old Sep 14, 2000 | 04:18 PM
LDY's Avatar
LDY
HAHAHA, typing with lips, hahaha. Yeha I wanted to know why you crawled under your car with it running? didn't exhaust burn you?
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
Fronzizzle
Aug 9, 2015 01:15 PM
1nastygta
Aug 8, 2015 07:38 PM
