how many ground cables?
Old May 29, 2003 | 08:25 PM
Kandied91z's Avatar
i'm thinking that i may be missing a ground strap on my block which may be a reason why i'm having troubles starting my engine.
how many are there typically on an engine and where abouts would they be located?
Old May 29, 2003 | 09:51 PM
Vader's Avatar
There is a braided ground strap from the rear of the right head to the firewall. There should also be at least one ECM reference ground in the intake near the distributor. Of course, the battery negative lead should ground at the engine, and the smaller battery negative lead should connect to the ground distribution node on the inner fender or radiator support.
Old May 30, 2003 | 01:35 AM
Kandied91z's Avatar
thanks, just wanted a basis to get started!
wigmobile
Feb 26, 2025 02:56 PM
MM2Robinson
Oct 1, 2017 09:16 AM
L0tuS
Oct 4, 2015 08:07 AM
gta892000
Sep 16, 2015 12:37 AM
corey8084
Brakes
Sep 15, 2015 08:14 PM
