Fuel Pump went...any easier way to do this?
Old May 30, 2003 | 09:48 AM
IrocAngel305's Avatar
i heard some people talking about "cheating" and cutting out a section in the hatch in order to reach the intank fuel pump. I am contemplating this and wanted to ask 2 things...#1 anyone have a diagram on where to cut? and #2 is this a good idea??? also how long should it take if i do it this way?. thank you
Nikki
Old May 30, 2003 | 10:10 AM
ede's Avatar
ede
don't cut the floor do it right way
Old May 30, 2003 | 11:50 AM
MX265
Guest
Posts: n/a
I think I read somewhere that some people were just running an inline fuel pump that could draw through the defective one. I'll have to see if I can find that article somewhere.
Old May 30, 2003 | 01:05 PM
thank you
Old May 30, 2003 | 01:59 PM
MX265
Guest
Posts: n/a
Here's a few discussions on this.
https://www.thirdgen.org/techbb2/sho...line+fuel+pump
Check these links out. You can also search for "Inline Fuel pump", and you should get a few hits here. Good luck. I know it's not much fun either way.
Andy
Old May 30, 2003 | 03:53 PM
Dan88IrocZ's Avatar
There's nothing wrong with cutting the floor. IMO it's actually smart...why?
I've had 2 pumps fail on me and because I had it done the 'right' way I lost a ton of money.
Old May 30, 2003 | 03:57 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
^ X 65476657876878978978978978978978
Old May 30, 2003 | 04:50 PM
f-crazy's Avatar
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
i had to cut a hole in mine...although i did have it arc welded back together...
to bad i dont have any pics...it looks like it wasnt cut at all
Old May 31, 2003 | 12:15 PM
MdFormula350's Avatar
i would just drop the tank and do it that way, i would also clean out the gas tank real good most likely paint it while its out and do other misc. stuff in that area.
Old May 31, 2003 | 01:06 PM
TekViper's Avatar
Car: 1990 Pontiac Firebird
Engine: 3.1L v6
Transmission: Automatic
if your gonna cut a hole to get to it, make it like a door panel u can pull off and put back on so if you ever need to do it again you can and the car is less "hacked up". i would personally do it the right way and drop the tank but making a door for it would be pretty sweet.
Old May 31, 2003 | 05:38 PM
f-crazy's Avatar
Engine: CARBED LT4
Transmission: MK6
i wanted to do it the right way...but the lip on the cat pipes broke so my i-pipe was welded on...i really didnt have a choice
i arc welded it back together so its probly stronger in that area...
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
