Got a new block
Old Sep 13, 2000 | 01:03 AM
Blade's Avatar
Got a new block
Hey guys ! The engine in my 92 Z28 "died" today. Stil driveable but not
fixable. The wrist pin on the #6 cylinder decided to walk out and carve a
nice deep hole in my cylinder wall.
Now I have a 91 350 truck block which is non-roller. (100654727). Problem
is.. I cant exactly use my roller CompCams XR270HR cam I had in there. It
was a pretty big cam too... Anyway, what I wanted to ask if what you
guys would recommend for this engine ? I'm gonna be using it with stock L98
ported and polished heads, and ported stock TPI intake and a stock TB. It
will have Edelbrock TES headers also. Any suggestions/recommendation would
be greatly appreciated
92 Z28 L98 350
Ported and polished heads, ported stock TPI base, ported plenum, Comp Cams XR270HR-10 cam (lift .495/.502 duration 218/224 lobe separation 110), Edelbrock TES headers, LT4 valve springs, Crane AFPR, Flowmaster catback with LT1 style tips, MSD coil & wires...
"Take that auto, drop it in first, hold the brakes, stomp the gas and grin from ear to ear! :-)
Old Sep 13, 2000 | 10:58 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
You can still use that roller cam. All you need is a set of "retrofit" roller lifters, a roller timing set (insurance mostly), and a cam button. All of these are available from Comp. The lifters aren't cheap but the roller profile is so much better than the flat tappet that you'd be shooting yourself in the shorts by downgrading.
I have a Comp XR282HR in my 400, it's great. It's much better than the 282S that I had for about 10 years. The roller lobes look almost square compared to the egg-shaped flat-tappet ones.
Old Sep 13, 2000 | 11:18 AM
Blade's Avatar
Yeah but see... if I had the money I would have bought a roller block to start with. What I would I like for now is to have a decent engine while I look for another roller block to build up and make a 383 out of. So what would u think a good cam would be, even though hydraulics are more inferior ?
92 Z28 L98 350
Old Sep 13, 2000 | 05:23 PM
Blade's Avatar
Well block is going to the machine shop tomorrow to see what can be done with it. I'm happy... heh
Old Sep 14, 2000 | 04:19 PM
md's Avatar
md
I'm surprised to here that block isn't a roller. In '89 GM went roller. '96 they started running roller rockers. I just rebuilt a 350 out of an '89 chevy 1/2 ton 4x4 and it had a roller. Do you have the engine's history, I'd be interested to here why it isn't a roller.
Old Sep 15, 2000 | 02:18 AM
formula90's Avatar
Car: 1990 Formula
Engine: 5.7 liter
roller in a 89? i dont know about that one. never heard that! i have a 90 350 and it just has the stock hydro cam and lifters. are you sure your cam is stock. let us know. i am very interested
I have experience...unfortunatly,its a result of bad judgement.
click below to check out MY FORMULA PAGE!
http://www.members.tripod.com/~Astra...uild/front.htm
or click below to email me
Astralbaby@webtv.net
Old Sep 15, 2000 | 02:44 AM
Colin 86&87 IROC-Z
Guest
Posts: n/a
no, GM went roller in 1987... 1986 was flat tappet. i know because i just finished a rebuild on my 87..
'86 IROC-Z 305/auto with no cat, performance chip, shift kit, and 4.11s
'87 IROC-Z factory loaded with every option, 84,000 miles
Webmaster: www.IROC-Z.org
Old Sep 15, 2000 | 03:27 AM
Blade's Avatar
We are talking about truck blocks here not FBodys. This is a 91 and it has the bosses for the spider, but the holes arent drilled.
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
skinny z
Oct 5, 2015 06:23 PM
92projectcamaro
Sep 29, 2015 07:07 PM
dusterbd
Sep 29, 2015 08:40 AM
