Where can I get a new 400?
Old Sep 13, 2000 | 11:52 AM
kiztope's Avatar
Car: 92 Formula
Transmission: A4
... with a 350 crank, and a decent set of heads... a good fuel injection setup......
Thanks,
Daniel
Old Sep 13, 2000 | 11:57 AM
FastBroker's Avatar
a 400 with a 350 crank won't be a 400 anymore. 400 has more stroke, ie 400 crank in 350 = 383... So??? 350 crank in 400 = 367ish, too tired to do the bore/stroke thing. Bigger bore/stroke in 400
Old Sep 13, 2000 | 12:06 PM
dwang's Avatar
if u want a brand new 400 block,, u have to go with gmpp bow tie block, or old's rocket block. the regular prodution 400 block only last 10 years. y do u want to go with 350 crank? building a 377(chp did a excelent articl on 377 vs 383(350 block with 3.75 stroke)))? it's cheaper and easier to build up a 400(if u can find a used block, or be prepare to shell out $1600 for the bow tie block). cubic inches is where hp/torque come from. just my .02
dw
Old Sep 13, 2000 | 02:20 PM
CHCKLS's Avatar
Car: 89 Iroc Z Cnvertible
Engine: 409 SR
Transmission: 6 speed
Wheeler Bros. has a 400 bare block fully machined for about $800 the last time I looked.
Old Sep 13, 2000 | 04:34 PM
kiztope's Avatar
Car: 92 Formula
Transmission: A4
Is the Bow Tie block just a bare block? No heads, no nothing?
Wheeler bros.? Do they have a web site?
Thanks so far.....
What about injection setups? I dont want a carb setup. Should I just pull the TPI setup and computer out of a 92 Z or something?
Thanks again,
Daniel
Old Sep 14, 2000 | 02:08 PM
dwang's Avatar
yupe bow tie block is the bare block,
go to a local swap shop, i still see pretty good 400 block(this is the production block 1970-1980) for about 500-600 dollars. the stock tpi will be too restrictive for a 400(the 350 tpi setup is the same as the 305). if you want to go with tuned port injection you have to go with either tpis mini ram, or accel super ram, or upgrad the tpi setup with biger everything(manifold, plenum, runner, throttle body etc)
dw
Old Sep 14, 2000 | 08:26 PM
lexussc94's Avatar
IF YOU ARE INTERESTED I HAVE A BRAND NEW ACCEL SUPERRAM/PLENUM KIT ,STILL IN BOX. I WANT 675 WHICH INCLUDES SHIPPING.ALSO HAVE A TPIS MINIRAM, USED BUT IN GREAT SHAPE. NOT SURE WHAT I WANT FOR IT YET.
Old Sep 14, 2000 | 09:40 PM
B L A D E's Avatar
What bank did you rob Kiz?
Old Sep 14, 2000 | 11:55 PM
kiztope's Avatar
Car: 92 Formula
Transmission: A4
No bank,
Im in planning stages. I want to know what to get, so I can start slowly buying things... I have a big garage to store stuff in.
BTW, I would really prefer to go with a new block, or newly rebuilt........
Old Sep 15, 2000 | 01:03 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Dont forget - bare block = no pistons, crank, heads, etc...
1983 Pontiac Firebird SE
LG4-Based Chevy 400
700R4 Tansmission
Modified 4 Barrel Q-Jet Carb
Accel Super Stock 8mm Wires
Edelbrock Pro-Flo Air Cleaner
3.23 Posi Rear
14X7" Cragar SS/T Wheels
35X4 CD/AM/FM Head Unit
100WX2 Amp
2 Pioneer 12" Subs in Custom Box
Old Sep 15, 2000 | 11:03 PM
dwang's Avatar
hello fellow massapequaian(is this even a word?? ) very interesting in thsoe mini ram.
dw
Hotrodboba400
Dec 10, 2019 07:07 PM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
FtrSpeedy
Sep 7, 2015 12:11 PM
