What spark plugs should I run?
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
A lot of people I know run NGK plugs.
Am I supposed to run the TR55 or the TR55VX (Platinum) on my LT1 with the mods in my sig.
What about on my bone stock 88 305 TPI Formula?
I am picking up some plugs tomorrow for both cars, just wanted to know which ones to get.
thanks.
Oh, and these are what the tips look like,
TR55
TR55VX Platinum
any other suggestions, bearing in mind that cost is a major factor.
$2.00/plug is the max I want to spend.
thanks.
TR55
TR55VX Platinum
Originally posted by Z_Ghost
On your bone stock 88 305 TPI Formula why not run AC Delco, they work really well for me and they are cheep.
I like NGK alot. I would pick up some TR55s for the LT1 but you cant run TR55s in the older heads as the reach is too long. L98s use the NGK UR4 I would imagine the 305 is no different but you might want to check out www.ngk.com to be sure.
Call me crazy, or cheap, or both
I've run the plain jane AC Delco plugs on every GM I've ever owned without every having a spark plug related problem. And yes, I've tried Bosch, NGK, etc etc.
One MAJOR reason I like the AC Delco, they are about a $1.00 each. So when ever I'm under the hood doing something else, especially now with headers making plug changes alot faster, I will replace the plugs, even though most times they really don't need it....but it's less than $10......
HTH
I need to drive down from Richmond one day and check out the LT1 swaps you wrenched on...
HTH
HTH
HTH
Come on down one weekens, you can check out the swaps as well as some of the other nice cars in the area. our local board is www.tidewaterracing.com
Car: 00 TA, 91 Formula, 89 RS
I like NGK. They took a lot longer to foul out on my Honda with worn piston rings than the A/C Delcos and Champions did.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
