Why's my stock L98 getting 8 MPG???
Old Sep 16, 2000 | 11:05 PM
a1987formula350cu's Avatar
It's only got 49k. The valve seals need to be replaced and I think an injector is clogged b/c I hear a clicking noise from the engine. You figure it out???
Old Sep 16, 2000 | 11:32 PM
irocz's Avatar
Car: '87 IROC-Z
Engine: 406 Superram/DFI
Transmission: Auto BTE 3000 conv
When was it tuned up (plugs, wires, cap, rotor) last? Have you changed the 02 sensor? It wouldn't hurt to set the IAC and tps just to be safe.
good luck,
87 IROC-Z, 5.7, auto, 3.27, leather, !cat, Holley fpr, K&N'S, SLP 1-3/4" Jet-Hot coated headers, SLP cam, $uperPITAram, Edelbrock lower intake, Holley 52mm tb, Dynomax/Flowmaster catback
Coming Soon - Fasttrack/Accell DFI
1989 Pontiac 20th Anniversary Turbo Trans Am - STOCK (for now)
SOLD ->91 Z28, 5.7, 3.23, Ported Plenum, Accel runners & lower intake, Accel distributor module, !dual cats, POS Edelbrock catback, K&N'S, ram air, tb airfoil, !tb coolant
Old Sep 17, 2000 | 06:09 AM
Colin 86&87 IROC-Z
Guest
Posts: n/a
how are you checking the gas mileage? you can NOT use your gauge! my '86 IROC is atLEAST 1/3 of a tank off of what the gauge is reading. the only way to guaranteed get the correct mileage is to fill your tank up so full all it does is click.. write down your milage and drive it for a whole tank, fill it up again until it clicks.. write down your mileage.. then the Calc is:
new mileage - old mileage == miles driven
gallons filled
then divide miles driven by gallons added and that's your mpg
ie. 200 miles driven divided by 10 gallons == 20 mpg
'86 IROC-Z 305/auto with no cat, performance chip, shift kit, and 4.11s
'87 IROC-Z factory loaded with every option, 84,000 miles
Webmaster: www.IROC-Z.org
Old Sep 18, 2000 | 10:55 AM
Colin 86&87 IROC-Z
Guest
Posts: n/a
i would also like to say as well that the valve seals being bad isn't bad at all! weird? not really, the oil provides a little bit of lubrication when you start your engine, saves wear & tear a bit.. just tell your friends it's called Oil-Tec and my motor clicks too, i have no idea what it is but I've heard the fuel injectors can do that.. i'm sure everything is fine, at 49k the motor should still be in great shape
Old Sep 18, 2000 | 11:51 AM
BubbasIroc's Avatar
i would try the marvels mystery oil in the engine and in the gas before i replaced my valve seals there is an article on this site about it...
Azrael91966669
25
Jun 20, 2017 04:04 AM
Genopsyde
Oct 7, 2015 08:35 PM
InfinityShade
Aug 22, 2015 08:00 PM
jpearcy1
Wheels and Tires
Aug 9, 2015 10:20 AM
