Got a battery drain problem....
Old Jun 3, 2003 | 09:38 PM
MikeZ28's Avatar
Car: 92 Z28 Z03
Transmission: 700-R4
Axle/Gears: 2.73 G80
I have a drain problem some where and i can't find it.
I have subwoofers and everything i check all that it seems ok.
my problem is let the car sit for 7 hours it has power. let it sit for another 7 to make 14 hours sitting...total dead.
Im lost.
before it would last like 2 days straight and it just start.
im lost......any tips?
Old Jun 4, 2003 | 02:49 PM
Vader's Avatar
You'll need to connect an ammeter in series with the battery. Once connected, remove fuses or disconnect loads one at a time while you monitor th eparasitic (standby) current. Once you see a significant drop, you will have found the most likely suspect.
It's also possible the battery is sulfated, and is shorting istself out at the bottom of the plates. To test that, disconnect the battery completely and load test it after sitting for the 14 hour trial.
Old Jun 4, 2003 | 06:00 PM
MikeZ28's Avatar
Car: 92 Z28 Z03
I forgot the battery is like a month old. Ok il have to try that.
I don't have a ammeter though.
what other methods could i use to find the source of the problem??
Old Jun 4, 2003 | 06:06 PM
rezinn's Avatar
Disconnect your negative battery cable and connect a test light between it and the battery. If it lights, you have a drain. Disconnect stuff until it goes out and you found the problem.
Falcon50
Aug 22, 2020 03:26 PM
3rd gen money
Oct 11, 2019 09:57 PM
RS Reaper
Oct 17, 2018 07:52 PM
drumstixer
Sep 29, 2015 03:02 PM
raymondandretti
Sep 27, 2015 06:43 PM
