who has the "hot cam"?
Old Sep 18, 2000 | 04:34 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
I've got the vortec heads and am wanting to use the lt4 cam. 400 hp is achievable with this cam and head combo.
My question is does this cam have a fuel pump lobe for a mechanical fuel pump?
Old Sep 18, 2000 | 05:27 PM
GhoSSt's Avatar
Yes, it has the mechanical fuel pump lobe. I'm using it in my '84 BIrd, with Vortech heads and the HOT cam w/ 1.6 RR's.
Kelly 'GhoSSt' Rosato
1996 Impala SS, 383 LT4 (14.65 up here, 13.24 lower)
1984 Firebird, 305 LG4 (Secret Engine Project)
1985 Camaro, 2.8 MPFI (My Daily Driver Project)
"And if you wrong us, shall we not revenge? Revenge. The villany you
teach me, I will execute, and it shall go hard but I will better the
instruction."
Shylock in Act III, Scene I of 'Merchant of Venice' by William Shakespeare
Old Sep 18, 2000 | 06:54 PM
Vader's Avatar
GhoSST!
Nice to see you here. I took your advice, bypassed the "hot" cam and got what must be a "steaming" cam. If I go to 1.6:1 (if Comp ever gets them made) I'll be at .544/.544 222/233/114°. Lots of lope, however, and I'm almost forced to do something about the converter and PCM to get the most out of it.
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
Old Sep 18, 2000 | 09:07 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
Thanks for the replys. What size carb and intake are you using? Also what gears. Just curious because I've got the 3.73's and a 700r4. I plan on using the new "Air Gap" Performer Rpm manifold for the vortec heads. Do you think that this combo could get me into the 12's at 341 ft. above sea level?
Old Sep 19, 2000 | 04:54 PM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
I've got a 350 9 to 1 compression, Hot Cam, Air Gap, 750 Carb, L98 heads with 2.02/1.60 valves, 3.70 gears and a 5 spd. I ain't nowhere near 12's. I still am having some problems tuning but the car falls flat on it's face in 3rd. At best I think the car is good for lower 13's. Your heads probably are better than mine though.
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
tommy z-28
Oct 6, 2015 10:58 PM
thekurlyone
Sep 30, 2015 12:54 PM
TX-SleeperC5
Sep 24, 2015 03:13 PM
Strick1
Sep 4, 2015 07:11 AM
