Got the car weighed.
Old Jun 6, 2003 | 04:17 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
I got the car weighed yesterday. What a pig!!! I have removed all the AC. The car weighed 3315. I thought they weighed 3250 stock. I was hoping for something around 3100. My buddies 98 TA weighted 3550ish and he has power everything. We both had full tanks of gas which (correct me if I am wrong) is about 8 pds per gallon.
Old Jun 6, 2003 | 05:31 PM
Spectre's Avatar
Car: Camaro Z281991 Engine: 5.7L/350 TPI Transmission: TH700R4 ··································· Car: Acura CL 1998
Engine: 3.0L/183
Transmission: 4 spd auto/OD
stock is 3450 i think.
3100, you could get aluminum heads,
FG hood, anything alu instead of iron..
the doors are heavy as hell..
I dont think weight reduction is worth it.
unless u plan to get alum.. heads..
Old Jun 6, 2003 | 05:45 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
weight reduction is worth it if you drag race the car or want slightly better gas mileage
Old Jun 6, 2003 | 05:53 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
very few v8 third gens were lighter than 3400 from the factory
Mine is 3200 with only an interior. (everything ^motor delete).
Old Jun 6, 2003 | 06:27 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Mine was 3370. T5 305 no A/C, no smog, small stereo with one 12" JL, 1/4 tank of gas, no back seat, 16" GTA crosslace wheels,.
Old Jun 6, 2003 | 07:55 PM
Blacker's Avatar
87 octane 6.200lbs/gallon
89 octane 6.210lbs/gallon
92 octane 6.413lbs/gallon
A little more info....... water is 8.330lbs/gallon
Old Jun 6, 2003 | 08:19 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
I wished I could find one. I want one that is exactly like the stock.
Old Jun 6, 2003 | 08:23 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Look at the '82/83 Z28s.. they had factory glass hoods
Old Jun 6, 2003 | 09:11 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
But they don't have the louvers.
Old Jun 6, 2003 | 11:56 PM
Ian_F's Avatar
Car: 1996 Jeep Cherokee
Engine: 4.0
Transmission: 5 speed
you think that is heavy! my car weighs 3776 lbs! Granted, it is a second gen, but that is almost two tons!
Old Jun 7, 2003 | 01:45 AM
onebadwagon's Avatar
if you think weight reduction isnt worth it, go race a couple of light cars, see how much easier it is to get sub 3000lbs moving compared to 3300ish.
less wear on all driveline parts, better fuel economy, the list never ends, as to why light cars rock.
adam
Old Jun 7, 2003 | 02:19 AM
jfreeman74's Avatar
Car: 1985 Iroc-Z
.1 for every 100 pounds. Weight reduction is a big thing.
Old Jun 7, 2003 | 05:11 AM
ronterry's Avatar
Car: '94 Corvette
Yeap 'Ian_F' my '81 is also a heavy monster. I think that’s why they have GM 10bolt 8.5"? Then again mine came with a TH-200C Go figure that logic?
----Off topic alert----
Hey mine does awsome on ICE! How about yours. People look at me crazy, but they do really good on ice for a sports car. I mean it's no front wheel drive, but then again it's not crap like the 3rd gen(spin when ever) or Vette(weather vane on the slightest slop).
My old 2nd gen was my all-weather ride for the longest time. Now it's relagated to a restoration in a few years. Till then, I have to mow the grass around her.
Ron
Old Jun 8, 2003 | 01:05 AM
Opha's Avatar
my lil opion is the 82 Z-28 hoods are the best, main reason is i have yet to see anyone around where i live with one. but there are a ton of irocs and RS with blisters and the shade things. My hood stands out and looks soo nice with my car. i'll get a pic of it after i get the tranny rebuilt ( 2 1/2 weeks to go) and it's all waxed up.
Im soooo excited, havent driven it since Oct.!!!!!
i miss it!
Opha
Old Jun 8, 2003 | 01:53 AM
trans87's Avatar
Car: 2006 Tacoma X-Runner
Engine: 4.0L DOHC V6
Transmission: 6-Speed Manual
Axle/Gears: 3:15 LSD
i miss it!
Opha
I know how you feel. I haven't driven my car since beginning of December Saw her run today though before we realized I had a runner gasket leak O well got some pics from today on my site.
Old Jun 9, 2003 | 10:10 AM
Tom84L69's Avatar
Car: 84 Z28
Engine: L69: cam and porting
Transmission: T5, 3.73 rear
Blacker,
How much weight for 110 octane Torco race gas? We always figured 6.5 lbs per gallon.
Old Jun 9, 2003 | 12:58 PM
iroc22's Avatar
My IROC weighed in at 3205 lbs with a half tank of gas.
Old Jun 9, 2003 | 09:52 PM
87cam305's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 305 (LG4)
I just checked my door jam sticker an it said 4,092 Lbs . It is a 1987 Sport Coupe Camaro with the stock 305 with A/C
If you want to see my car go here: http://lowrider.cardomain.com/id/badass87camaro[/URL]
Old Jun 9, 2003 | 10:46 PM
Tom84L69's Avatar
Car: 84 Z28
that is probably max weight or gross vehicle weight, not the actual weight of your car.
Old Jun 9, 2003 | 10:47 PM
charlie31603's Avatar
Car: 1987 Chevrolet Camaro Z28 IROCZ
Engine: L98 350, mini ramed and camed
Transmission: T56 6 speed manual
Axle/Gears: 10 bolt 3:73 limited slip
Weight reducion is every thing! my camaro use to weigh 3250. My friend has a mits. mirage that weighed 2300, and with the stock motor with an intake it runs a 12.8 in the 1/4! and I ran a 14.9 with twice the motor (350 with intake and carb).
Old Jun 10, 2003 | 12:29 AM
JERRYWHO's Avatar
Dave has them, just look at the bottom of the page
http://members.***.net/iroczdave1/IR...rts%20Page.htm
Jerry
Old Jun 15, 2003 | 12:16 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
sticker on oyur door does not tell you weight of car, the numbers are GVW rating numbers, the max weight that car can weigh when is loaded down with max cargo, tells you total and thnre also front and rear spearately,
you think that the 5500 or so lbs stamped on the truck vin plates means it weighs 500 or so lbs ? nope, they actualyl weighed anywhwhere from 3500lbs in the 67-72 years, to around 4200lbs in the 73-87 years, at least 2wd anyways
i had a 68 longfleet with 355 and th350 and original 3.73 12 bolt, originally a 307 2 bbl and saginaw sm326 three speed manual on the column, and it only weighed 3850 on the scrap yard scale, it was a very quickkkkk truck ! i miss it alot..... :S all those eyars trucks needed to eb sleepers was a mild engine and good tranny and good rear tires and stick on some 71 72 or 73-87 spindles and rotors and calipers onto front of, and a 67-72 c20 brake booster and 71 72 master cylinder to make good safe stops with,
i will find another 68 longfleet to have fun with some day, cant wait!
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
