what intake can fit under hood and run 6000 rpm's
Old Sep 18, 2000 | 10:23 PM
brian86Z's Avatar
i am running the edelbrock performer and a carb now. i tried raising my low rise air filter about 3/4 of a inch wich is how much higher the RPM is sapose to be and i cant get the hood closed. does anyone make a step up in manifolds that will fit under the hood of a stock 86Z28 hood?
Brian
Old Sep 18, 2000 | 11:16 PM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
i know the rpm is very close and hits on most. possibly the weiand xcellerator. anyone tried it yet???
Old Sep 18, 2000 | 11:49 PM
CamaroMike's Avatar
The GM intake on the ZZ4 easily goes to 6 Grand and clears stock hoods.
84 Camaro ZZ4 with HOT cam. 1.88 60' (12.98 @ 105MPH E.T.)
Other Mods: You name it and I have probably changed it.
91 Firebird 5.0L TBI
ASE Certified Auto Tech
LIVE AND DIE BY THE ALMIGHTY BOWTIE!
Old Sep 19, 2000 | 12:05 AM
Mark305TBI's Avatar
Car: '00 Chevrolet Corvette
I've gotr a Torker II, 1" TBI adaptor, and a 14"x3" open element under my hood. It's damn close, but the hood closes.
-Mark W.
<A HREF="http://www.angelfire.com/al3/thegreycar">'88 SC Camaro w/ 305 TBI</A>
Old Sep 19, 2000 | 12:27 AM
MAMASAIDKOUOUT's Avatar
VICTOR JR!!!!!
"to hell with gas mileage and looks! this is for horsepower"
Old Sep 19, 2000 | 03:13 PM
RednGold86Z's Avatar
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
Does the Wiend Stealth fit? With either a Holley or Edelbrock? I'd like to know.
Old Sep 19, 2000 | 04:03 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
heres another vote for the Edelbrock Torker II, i only have a 400 cfm throttle body and it pulls hard to 6k and beyond
Old Sep 19, 2000 | 07:11 PM
Jester's Avatar
Wieand Stealth. Mine pulls as high as I'll take it.
Old Sep 19, 2000 | 07:15 PM
Formula-91's Avatar
One more for the Torker II. I've got a Holley 750 sitting on a 1/2 inch Nitrous plate, and it clears.
91 Firebird Formula. Converted to carb. Holley 750. Forged Flat top pistons. 10.5 to 1 compression. ZZ-9 Cam. Ported L98 Heads.
150 shot NOS, 700r4 w/ 3000 rpm converter and 3.73s in the back. Headers w/ full dual exhaust. 27.5 inch McCrearys. (free slicks)
12.98 @ 106 Natural,
11.83 @ 113 NOS.
Old Sep 19, 2000 | 07:17 PM
Formula-91's Avatar
BTW, the only reason I shift at 6200 is the stock lifters. By mistake, I've shifted at 6500, and it pulls hard all the way there.
11.83 @ 113 NOS.
Old Sep 19, 2000 | 08:32 PM
brian86Z's Avatar
isnt the torker II larger(heigth) then the performer RPM?
Brian
Old Sep 19, 2000 | 10:12 PM
Ray87Z's Avatar
Car: 94 Z28
Engine: LT1 w/ headers, catback, CAI, tune
Axle/Gears: 3.23s
Well I've got the RPM under my stock 87Z's hood using a drop base 14x3 inch aircleaner assembly. The wingnut rubs the hood so there is no room for a non drop base aircleaner.
Ray87Z
-Vortec headed 350.
86 IROC w/ a cammed 305 TPI.
Formerly Ray86IROC.
www.inter-scape.com/Ray
Old Sep 19, 2000 | 10:39 PM
brian86Z's Avatar
i was just checking uot the specs on the torker II and it looks interesting! it has a low profile but is a single plane intake. how much bottom end are you guys loosing with this intake? can it still be a nice daily driver?
thanks for all the feedback
Brian
Old Sep 20, 2000 | 05:52 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I've got the Performer RPM 7101 Dual Plane Hi-Rise intake on my 305 with an Edelbrock open element air cleaner that drops over the edelbrock carb. It seems to fit "ok".
I'll have pics online tomorrow evening.
I like my new setup a lot, lots of torque (I can smoke the tires all day long) and lots of top end. If my tach is correct, I got my car to nearly 160mph one evening. 4000rpms in 5th gear.
Zepher
'86 Pontiac Trans Am WS6, 5 Speed:
Edelbrock 1406 Carb, Edelbrock Performer RPM 7101 Intake Manifold.
Edelbrock Open Element Air Cleaner: Flowmaster Exhaust, 160* Thermostat,
Grant GT Steering Wheel, MSD HEI Coil, Taylor 8mm Wires, Recaro Seats,
Alpine CD+Changer,Rockford & Soundstream Amps, Premier TS-1040C Subs, Polk Audio highs/mids.
86 Trans Am & Girls
[This message has been edited by Zepher (edited September 20, 2000).]
Old Sep 20, 2000 | 12:35 PM
Blade's Avatar
Is that with a 350 shortblock under those heads and cam ???
92 Z28 L98 350
Ported and polished heads, ported stock TPI base, ported plenum, Comp Cams XR270HR-10 cam (lift .495/.502 duration 218/224 lobe separation 110), Edelbrock TES headers, LT4 valve springs, Crane AFPR, Flowmaster catback with LT1 style tips, MSD coil & wires...
"Take that auto, drop it in first, hold the brakes, stomp the gas and grin from ear to ear! :-)
Old Sep 20, 2000 | 03:48 PM
Auggie's Avatar
Car: 1984 Z28 Camaro
Engine: H.O. 355 NOS
Well, heres my .02 ! The stock alum. 1984 Z28 intake measures 2.940" in the front and 4.316" in the rear. If you have an NOS plate & gaskets it will measure 3.591" in the front and 4.967 in the rear. (Nos plate = .521" and (1)gasket = .065 (.130") for a total of .651"). I have a 14" x 3" drop base, home made alum. duel snorkel air cleaner. I put silly putty on the air cleaner in (5) places. Front, rear, center, left side and right side and closed the hood. (Frt = .700" Cnt = 1.300" Rear = 2.300" R/S = 1.900" L/S = 1.800") So there is alot of room with a stock Z28 man. For you Holly guys Weiand makes a real nice 360* man. called the X-CELerator #7547 that should fit with no proublem. For you Q-Jet guys Weiand makes a 360* man. called the Team "G" Street Ram #7525 (may also be called the Stealth) that should also fit. DO THE MATH!!!
P.S. You may have to cut off the bolts that hold the hood opening covers.
-Auggie-
[This message has been edited by Auggie (edited September 20, 2000).]
Old Sep 20, 2000 | 05:12 PM
Cosmik Debris's Avatar
I have an RPM manifold, NOS plate and a drop base aircleaner on my 84 HO. It just fits but I have the power bulge hood from 84. The wing nut from the aircleaner goes into the bulge.
Cosmik Debris
Frozer!!!
Jan 19, 2024 04:55 PM
Bradsaundry
Aug 12, 2015 12:34 AM
bryan623
Aug 10, 2015 11:33 AM
3rdgenparts
Aug 6, 2015 09:03 AM
