Sensor Problem
Old Sep 20, 2000 | 03:35 PM
JJ63's Avatar
Car: 92 Trans Am
Engine: 350 tpi
Transmission: 5 Speed
Sensor Problem
I was making some adjustments today and I noticed some kind of sensor attached to the passenger side head, in between the 2 exhaust ports closest to the firewall. Problem is that nothing is attached to this sensor and I can't find any loose wires. My question is what is this sensor, I think it is the fan temperature sensor? More importantly, where would a wire lead from this sensor. Thta wire must be somewhere under there, if I knew where it started I could find the damn thing.
92 1LE Trans Am
5.0 Liter, 5 speed
SLP Headers
Dynomax Cat-back
SLP Cold Air, Chip
SFC, Strut Tower Brace
Old Sep 20, 2000 | 04:04 PM
ede's Avatar
ede
i believe it is the fan switch. the wire would go into a loom and run towards your fan.
Old Sep 20, 2000 | 05:37 PM
wm_sorg's Avatar
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
If it screws into the block itself then it is the knock sensor.
db057
Sep 4, 2015 07:57 AM
soarestransam
Aug 24, 2015 08:15 AM
Bert87
Aug 23, 2015 03:50 PM
92camaroJoe
Aug 13, 2015 06:07 AM
