cant screw in oil pressure sender
Old Jun 9, 2003 | 01:28 AM
Diggler86's Avatar
Car: 86 TA
Transmission: 700R4 - 2200 stall
Axle/Gears: 3.42 posi
ok i've tried bog warner (pep boys) and niehoff (autozone) and i cant get either one to screw in. they both look exactly the same. the difference thought between them and my existing one is that my current one is tapered at the very end. I'm guessing this is why I cant screw it in? Anyone have any advice? B4 I pay out the a$$ for the dealer one? Which Im not even sure will work either?
this is in an 86 305 TPI
Old Jun 9, 2003 | 02:27 AM
OMINOUS_87's Avatar
Should be 1/8 inch NPT fittings. I am running an assortment of elbows from the Home Depot with no probs.
Old Jun 9, 2003 | 05:10 AM
ede's Avatar
ede
yep 1/8 npt, the taper should help since the end of the sender threads would be a bit smaller than the holes it's going in.
Old Jun 9, 2003 | 10:09 AM
Diggler86's Avatar
Car: 86 TA
i'm a bit confused. youre telling me that the hole is 1/8 NPT, but the replacement senders i'm trying are not?
and i can get "adapters" from home depot?
Old Jun 9, 2003 | 10:33 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It's all 1/8" NPT.... the hole in the block, the adapters, the replacement switches, GM ones, everything. They're all the same.
Sounds to me like you haven't quite got it lined up right or something.
Old Jun 9, 2003 | 11:23 AM
Diggler86's Avatar
Car: 86 TA
hmmmm... the burn on my thumb would probably disagree... i guess i'll try again... seems like im the only one with the problem.
Old Jun 9, 2003 | 11:34 AM
JR305's Avatar
If your oil pressure sensor is right by the oil filter their are two holes right next to each other. You might be trying to screw it into the wrong one (the smaller one).
Old Jun 9, 2003 | 12:10 PM
Diggler86's Avatar
Car: 86 TA
the sensor is on the back of the engine on the drivers side near the distributor. i can screw the original one in easy no problem, just not the replacement.
Old Jun 9, 2003 | 01:11 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Are you trying to screw the sending unit into the block or into the elbows? If you replaced your sending unit you should have not had to mess with the crap that screws into the block.
Old Jun 9, 2003 | 01:32 PM
Diggler86's Avatar
Car: 86 TA
forgive me because i am not very engine saavy... all i want to replace is the bell shaped pressure sender..
i just unscrewed it (i think from the block). i didnt remember seeing any elbows.
my pressure gauge would fluctuate for a while, then this weekend it went down into the red. i almost messed my pants but im pretty sure its just the sender. there was oil all over the connector like it was leaking out the wrong end.
Old Jun 9, 2003 | 04:14 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Exactly. The pressure sending unit is the bell shaped thing that sits on top of the block at the back drivers side of the engine.
Old Jun 11, 2003 | 01:16 AM
Diggler86's Avatar
Car: 86 TA
well i ponied up for the ACDelco one and it screwed in ok. dunno.
good news is the pressure is back up
about 35 warm idle and up to 60 on cold throttle.
89GTAOz
May 16, 2020 09:31 AM
xxx3man`
Sep 23, 2015 10:37 PM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
