How do u know when to change a fuel filter??
Old Sep 19, 2000 | 10:19 AM
IROC-ZTWENTYGR8
Guest
Posts: n/a
[This message has been edited by IROC-ZTWENTYGR8 (edited September 19, 2000).]
Old Sep 19, 2000 | 10:28 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Well, it's supposed to be done in intervals like an oil filter, and like an oil filter, it's neglect only becomes obvious when it's grossly overdue. If you start having unexplained lean WOT situations, or a stumble under load, it could be getting plugged up.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Sep 19, 2000 | 10:50 AM
IROC-ZTWENTYGR8
Guest
Posts: n/a
Thanks, but where are they located and how much for a good 1??
Old Sep 19, 2000 | 10:51 AM
IROC-ZTWENTYGR8
Guest
Posts: n/a
Double Post
Old Sep 19, 2000 | 11:58 AM
Jim85IROC's Avatar
They are in-line with the fuel lines, right in front of the rear-axle on the driver side. It's easy to spot when you get under the car. it's a round cyllinder, about 2" in diameter, maybe 3 or 4 inches long. Make sure that when you decide to replace it that you use tubing wrenches and not normal wrenches. If there is any rust at all on the ends, spray the crap out of it with penetrant and go at it later. If you twist the gas lines or strip the bolts you're in for a major headache.
The IROC Homepage
Old Sep 19, 2000 | 01:36 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I don't think there are any "good ones", either. Summit made a version for $20, but they stopped... I guess the demand wasn't high enough. For a stock motor I assume the Ac/Delco ones flow enough. You can find 'em at Strauss Auto, Walmart, Pep Boys, etc for about $10.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
Old Sep 21, 2000 | 11:29 AM
IROC-ZTWENTYGR8
Guest
Posts: n/a
Thanks guys!!
Old Sep 21, 2000 | 02:33 PM
Iroc_Z28's Avatar
i change mine about ever 10,000 miles or so for best performance...
Infested
May 22, 2018 11:56 PM
Logan Bryant
Aug 27, 2015 11:52 AM
92camaroJoe
Aug 13, 2015 06:07 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
