Non-Tilt steering col avail?
Does anyone know if any third gen's came with non tilt steering cols? I'm halfway interested in swapping over to a non-tild col if one is avail.
TIA!
- Nick
'92 Z28 - CMC #??
TIA!
- Nick
'92 Z28 - CMC #??
Its a road race car. The tilt col in the car is a bit loose and wiggles a bit. Its a bit unerving to have the wheel move in the middle of a turn.
Does anyone know if they are interchangeable?
Thanks!
- N
Thanks!
- N
Car: 1986 Firebird
Engine: 2.8 V6
My '86 Firebird (2.8) has one also.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
My 86 firebird and my 86 camaro both had/have a non-tilt column. BUT, a tilt column won't have any slop if it's in good shape, so you may want to consider fixing what you have. If you want a non-tilt column, I may have one for you. I've got a tilt column that I've been meaning to put into the 86, and if you want the solid column maybe I'll get around to doing the swap.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
The IROC Homepage
My '86 doesn't have tilt and the column is loose as hell. I have to take it apart and tighten it down. Don't believe that the tilt columns are the only ones that get loose, not true. I have a spare just incase mine won't tighten up, and it is not tilt either.
350 Vortec, forged flat-tops, CompCams XE268, Edlebrock RPM, Holley 3310, TH350 w/Holeshot 2400, 3.23 posi, Heddman shorties, HEI
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Except for the windshield wiper switch being wired differently on the 82-83 models, they are interchangeable, AFAIK.
Pete
Pete's Place
Pete
Pete's Place
bubbaz28
Sep 18, 2015 02:09 PM
83 Crossfire TA
Sep 18, 2015 12:01 PM
punkmaster98
Sep 8, 2015 09:45 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
