can get it to start but won't stay running help
Old Sep 22, 2000 | 02:35 PM
lexussc94's Avatar
Have an 85 iroc tpi with a 305. Swapped in a 406 with a superram,24lb injectors,new coil,wires ,ect. I can only get it to run if i spray starting fluid in the tb. It has fuel pres. It only runs for a few seconds unless i spray the starting fluid. I replace the stock computer but still nothing. It sounds like a fuel prob but fuel pump works. Injectors are not leaking. Someone please help! thanks, Mike
Old Sep 22, 2000 | 02:36 PM
lexussc94's Avatar
Oh injectors are wired correctly I made sure of that ,plus I checked thanks
Old Sep 22, 2000 | 02:37 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
The timing's fine, right?
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
Old Sep 22, 2000 | 03:32 PM
84IROC's Avatar
I would have to agree with Tom it sounds as if the timing is off. Most likely the distributor, not the cam because you stated it would run a little bit. This is a common mistake just check the rotor to see if it is pointing at #1 position on the cap with the engine at top dead center #1 firing.
You can also "pre-time" the base timing by disconecting #1 spark plug and put an old plug in the boot and hold it to ground. now with the ignition on engine off turn the distributor quickly and watch for the spark. You need to try and stop the distributor right when you see the plug fire and you should be set.
"84Z28/'91 305TPI comp cam flowmaster TB coolant bypass/shutoff valve to heater core MAT relocated Ram-Air(home-made) gutted air-box IROC ground effects/wheels GY245/50's 700R4 superior shift kit/ corvette servo(excellent shift kit BTW) Rebuilt engine and transplanted it myself. Love this engine!
LOW performance people should drive low performance vehicles!
Old Sep 22, 2000 | 06:40 PM
lexussc94's Avatar
I checked timing and even had my mechanic check it and it was right.Could this be from a bad ground? Anything that comes to mind let me know. thanks guys, Mike
apo_bailon15
Mar 28, 2016 05:20 AM
Jae992
Aug 27, 2015 09:07 AM
justin57
Aug 20, 2015 07:05 PM
Sherpajames
Aug 7, 2015 06:56 PM
