cam swap, questions
Old Sep 23, 2000 | 06:38 PM
JDMZ28's Avatar
Car: 2KGTP
Engine: supercharged 3800 L67
Transmission: 4T65E
Axle/Gears: 2.93
cam swap, questions
I have an 87+up L98 350 with roller cam. I'm putting in a more radical flat tappet, I read that all I have to do is get standard length pushrods, it that true? Is the stock timing chain compatible? Has anyone done this? Thanks.
1986 CAMARO Z28 -> 150,000 original miles, 89' vette 350 block, Holley 650 DP, Weiand intake, 1.6 rockers, 1 5/8" headers, no cat, 2 1/2" Flowmaster catback, Mallory coil, March pulleys, T5 with 3.35 1st gear, 90% Centerforce clutch, 3.73 posi, Eibach 1" drop springs, reinforced LCA's w/bushings, Subframes connectors, polyurethane swaybar bushings/endlinks, 2 12" Sound Streams, 2 Infinity 6X9's, 2 Pioneer 6X9's, 800 watt Lanzar Vibe amp. ET 13.22@ 106.4MPH Next mods-> Adjustable panhard rod, LCA lowering brackets, homemade ram air, B&M shifter.
Old Sep 23, 2000 | 08:31 PM
ede's Avatar
ede
never done it but i'm sure it'd work as you said. i believe some people have had problems with the knock senser after cam swaps.
Old Sep 23, 2000 | 11:53 PM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
I'm not for sure, but don't you have to change the lifters? And they may not fit in the lifter bores because roller lifters (and their bores) are not perfectly round, they have a flat spot on each side so the lifter doesn't go in crooked. But like I said, I'm not sure... I'm sure someone else around here could enlighten us, though.
Old Sep 23, 2000 | 11:57 PM
JDMZ28's Avatar
Car: 2KGTP
Transmission: 4T65E
Axle/Gears: 2.93
I'm not worried about the knock my engine is completely manual. I was wondering if there is a difference between the timing chains also. Do you think I'll be able to use a non roller type 350 timing chain?
Old Sep 23, 2000 | 11:58 PM
JDMZ28's Avatar
Car: 2KGTP
Transmission: 4T65E
Axle/Gears: 2.93
Yes you do have to change the lifters, but I'm pretty sure they'll fit.
Old Sep 24, 2000 | 12:01 AM
Mark305TBI's Avatar
Car: '00 Chevrolet Corvette
If you use a flat-tappet cam, you'll have to get a timing chain for a pre-87 engine. The crank gear is the same, but the cam gear has a similar, but different, bolt pattern. I've seen it first hand, having accidently bought a pre-87 timing set for my '88 305...
-Mark W.
<A HREF="http://www.angelfire.com/al3/thegreycar">'88 SC Camaro w/ 305 TBI</A>
Old Sep 24, 2000 | 12:04 AM
JDMZ28's Avatar
Car: 2KGTP
Transmission: 4T65E
Axle/Gears: 2.93
When I buy the gasket kit can I interchange gaskets since I have an 87+up engine but I use 55-85 valve cover gaskets?
1986 CAMARO Z28 -&gt; 150,000 original miles, 89' vette 350 block, Holley 650 DP, Weiand intake, 1.6 rockers, 1 5/8" headers, no cat, 2 1/2" Flowmaster catback, Mallory coil, March pulleys, T5 with 3.35 1st gear, 90% Centerforce clutch, 3.73 posi, Eibach 1" drop springs, reinforced LCA's w/bushings, Subframes connectors, polyurethane swaybar bushings/endlinks, 2 12" Sound Streams, 2 Infinity 6X9's, 2 Pioneer 6X9's, 800 watt Lanzar Vibe amp. ET 13.22@ 106.4MPH Next mods-&gt; Adjustable panhard rod, LCA lowering brackets, homemade ram air, B&M shifter.
Old Sep 24, 2000 | 12:07 AM
MRZ28HO's Avatar
Car: was: 1984 Camaro Z28
Engine: was: L69
Transmission: was: 700-R4
Yup, the timing chains are different. So far, you need: Timing chain for SBC I, Flat tappet hydraulic lifters, 7.794" long pushrods and the cam. Why not just stick with a roller cam, more aggresive profile with less duration, less heat due to reduced friction?
George P. Lara
1994 Z28 LT1 T56
1984 Z28 High Output
Member: SCCA, SCFB, SC3GFB
Old Sep 24, 2000 | 12:18 AM
JDMZ28's Avatar
Car: 2KGTP
Transmission: 4T65E
Axle/Gears: 2.93
Don't get me wrong I love the roller one but it just isn't big enough. The cost doesn't justify the power I would only get like 10hp at the most. I priced the swap with the flat tappet to be only 195 bucks. Now if I got a roller:
LT4 hot cam kit: 335 (my price)
(any other would be 250 cam and 75 springs)
lifters : 170 (mine tick)
timing chain : 75
gaskets : 40
+____
620
That's 425 bucks more.
Old Sep 24, 2000 | 09:55 AM
MIKES 88GTA's Avatar
Go to the GM parts direct website, the link is on one of my posts a little farther down, this site realy changed my thinking of going to regular old hydolic cam, ZZ-3 cam for $159,the ZZ-4 springs for around $25 a set(ordered by twos)$2.95 per cylender.
The tpis cataloug has ALUMINUM roller rockers for $124 bucks 1.5s or 1.6s.
Shop around before ditching the roller setup.
Also I've heard of a guy I believe his name is something like Chet Hurburt, that grinds his own cams for around $160, I was told his ad can be found in National Dragster cataloug
but I can't find the cataloug yet.
Good luck.
88 black gta
tb coolant bypass
gutted maf
gutted air boxes
no cats or smog
700r with a snior citizen discount
bald tires
Frozer!!!
Jan 19, 2024 04:55 PM
gta90
Sep 15, 2015 04:00 PM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
Fronzizzle
Aug 9, 2015 01:15 PM
