replacing thermostat, having a little trouble
Old Jun 15, 2003 | 05:41 PM
prockbp's Avatar
Car: 1989 IROC-Z
Engine: 1992 TPI 350
Transmission: 1989 T5
Axle/Gears: 1992 10 Bolt Rear w/ 3.42 gearing
ok.. i have a '89 IROC with the LB9... 80k miles
i figured i would replace the thermostat since i'm sure it has never been done before...
but anyway... i'm trying to remove the bolts for the housing, and they won't budge...
i sprayed some penetrating lube on them and let them sit for a while and then came back and got the one on the back side to move a little but it's taking a lot of torque to get it to move... i feel like i'm going to break the bolt off
anybody else ever had this problem? i've replaced stats before on my old z28 and brothers transam without problems
does it sound like the bolts are just frozen into the intake? it might just be time for a new intake if that's the case
thx for the help
Old Jun 15, 2003 | 06:44 PM
owned's Avatar
uh oh.
Whats happened is the iron bolts have corrode-welded to the aluminum manifold. This happens when anti sieze was not used.
I'd try hitting it with an impact and a prayer. If you just keep applying constant pressure, it's gonna snap for sure.
But I would be prepared to drill it out.
Old Jun 15, 2003 | 06:46 PM
Z_Ghost's Avatar
If you still have a seal I would start the car up and get it hot, then shut it off and spray the heck out of the bolts. Keep spraying and let it cool down all the way, that might help.
Old Jun 15, 2003 | 07:11 PM
hydric's Avatar
Car: 1985 Iroc-z
Engine: 355 sbc
personally I would hit it with hammer and throw a torch on it n get them glowing red then an impact. thats prob your best bet.
Old Jun 15, 2003 | 08:12 PM
prockbp's Avatar
Car: 1989 IROC-Z
thx for the replies guys.....
i ended up just spraying some more penetrating lube on there and getting out my 2' homemade breaker bar
it worked.. didn't break the bolt... so i guess i don't have an excuse to buy a kickass intake
i cleaned the bolts and holes as good as i could and antisiezed them to death
Old Jul 27, 2003 | 01:55 AM
irocet305's Avatar
Car: 91 Z28
Engine: L98 350
Transmission: Tire Chirpin A4
OK, I read this....I broke the bolt on mine. What size bolt to I need to replace it, it's a 9/16th head, what size drill bit and what size tap? HELP ME PLEASE!!!!
Old Jul 27, 2003 | 03:56 AM
ede's Avatar
ede
3/8-16 by what ever length
Old Jul 27, 2003 | 09:31 AM
irocet305's Avatar
Car: 91 Z28
Engine: L98 350
Thanks ede! Wish me luck.
italiano67
Dec 11, 2016 09:21 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
EFR2000
Aug 18, 2015 08:54 PM
perZ
Aug 15, 2015 01:17 PM
