Smooth Idle When It Warms Up Just Dies
Old Jun 16, 2003 | 09:25 AM
cherryred89's Avatar
Car: 1989 camaro
Engine: 305c.i.d...... FOR NOW
Transmission: 700R4.....FOR NOW
Axle/Gears: 3.42 moser posi
Hey guys I have a 89 camaro RS with a 305 tbi the car runs great has good power but sometimes when its warm and sitting at idle it will all of the sudden just die but it will start right back up and run fine the idle speed is at 500 rpm that is spec for this car I've replaced the tps and the iac every sensor on this car is new plugs and wires are also new I've tried eveything but cant figure it out HELP!!!!!
Old Jun 16, 2003 | 10:21 AM
Vader's Avatar
Idle speed is 500RPM? That's the idle speed to adjust the minimum air position of the throttle plates, but once the IAC is enabled, the target idle should be closer to 600-650 RPM in drive. Did I misunderstand your statement?
Old Jun 16, 2003 | 12:31 PM
myz28u's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
I idle at like 400 in Drive and havent ever stalled.
Old Jun 16, 2003 | 12:49 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
the tbis have a really low idle speed. IIRC the base idle speed is like 450 rpms from the factory.
Old Jun 16, 2003 | 12:59 PM
demonchild's Avatar
probably getting to hot around the tbi unit and vapor locking
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
TBRays98
Sep 6, 2015 05:05 PM
IROCtometal
Sep 2, 2015 02:01 PM
