145 speedo gear with 85mph speedo?>>
Im probably stupid for asking but what if i get some white guages are for a 145 speedo and just change my speedo gear. The white faces will cover the whole thing anyways or do i need to just buy the whole speedo and gear? Thanks
85 Z/28
Mods: Flowmaster 80 ,Cam: 443 465 214 224 112,Comp Cams 981 springs& Retainers,Hypertech stage 2 chip, MSD 8.5 Super Conductors,Hypertech AFPR,F*rd 19# injectors,Ported plenum, K&N filters. And much more to come.
85 Z/28
ede, what im trying to say is: I have an 85mph speedo but i want a 145mph speedo. If i put white guage faces that are made for a 145mph speedo over my existing ones can i just change the speedo gear for a 145mph unit? Sorry for the confusion
[This message has been edited by Platinum (edited September 25, 2000).]
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I suppose it MIGHT be possible, as long as your ECM doesn't expect to have a meaningful signal from the VSS. You might not be able to get the right ratio out of the available gears though.
1984 Silver Z28, 383 cid long-rod 4 bolt SBC, ARP Bolts, 2 1/2" Cowl w/ Cold Air Induction, 600 cfm Performer Carburetor, Torker II Intake, Performer RPM Heads, XE268H Cam, Roller Tip Rockers, MSD6A Ignition, Blaster2 Coil, HEI Distributor w/ Adjustable Advance, 700R4, TransGo SK, 2.73:1 Limited Slip Dana 44, Terminator Headers, Custom 3" TIG Welded Stainless Exhaust, Flowmaster Muffler, 4 Wheel Disc Brakes, Oil Cooler
Transmission: 4L80E/4L80E
The gear from the 145 speedo has nothing to do with it. All speedos are calibrated to run at the same cable revolutions per mile.
What I think you are trying to do is speed it up by a factor of 1.6 so you can use the KPH scale as MPH. That will make your odometer a kilometer unit , but you'll be reading kilometers per hour as miles per hour.
But, as Apeiron says, you'll mess up your VSS, unless you can figure out a way to burn a chip to compensate for that.
82 Berlinetta, orig V-6 car. Rescued w/86 LG4/TH700R with all harnesses, sensors, ECM, etc. 2.73 open, cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LB9 w/ZZ3 cam, ported heads, exhaust, paint, etc.).
57 Bel Air, my 1st car. Currently 396 .030 over, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & shift kit, 3.08 10-bolt, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
Reading what you said again, no that's not what you're trying to do. To restate, speedometers are calibrated to work at a set cable revolutions per mile. Just changing the face won't change that, and it won't give you accurate readings at any time.
Either speed up the cable like I said in the above post, or get a 145 mph calibrated unit.
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Ok, since nobody apparently understood what you were asking, I'll try. The only difference between the 85 speedo and the 145 is the gearing between the cable and the needle, so if you did change it, it should work. BUT, good luck finding just the gears, and IF you can get it apart, it will probably never go back together again.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
The IROC Homepage
I dont think it will work because when you install the white face guages you must line up the original numbers with the numbers on the white faces to allow light to come through when driving at night. If you only drive in the daytime I suppose it would work.
Engine: 383 Carb
Transmission: 4L60
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
