car stalls at idle...what could be the problem?
Old Sep 26, 2000 | 11:25 AM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
i recently advanced the timing on my car and lately it has been stalling at idle. the idle bounces up and down sometimes, and stalls. could it be too advanced? i didn't think that this could be the problem, buty who knows. what else could be causing this? other than that, it runs pretty good, no other problems.
-Brian
1991 Camaro RS
Ultra Blue Metallic, T-Tops
GM 350 HO Crate Engine - Vortec Heads, Edelbrock Performer Vortec Intake, Holley 670 CFM Throttle Body, Open Air Cleaner w/14"x3" K&N, Edelbrock TES Headers, Edelbrock Victor Series Water Pump, Accell Superstock Wires, Cap, and Rotor, MSD Blaster Coil, Hypertech Fan Switch & Thermomaster Chip, AC Delco Rapidfires, 3" Cat Back, Flowmaster 40 Series Muffler
700R4 - 2,400 Stall Converter, Vette Servo, Shift Kit, B&M Transcooler
Brian's 1991 RS
Central NY F-Body Association
Old Sep 26, 2000 | 11:45 AM
84IROC's Avatar
My MAP sensor was causing that condition on my engine. How much did you advance the ignition? If you advanced the timing too far the engine ~could~ be detecting some detonation and is having to contantly retard and advance the timing although I do not believe this is very likely. Try retarding the base ign. timing and see if the the problem persists.
"84Z28/'91 305TPI comp cam flowmaster TB coolant bypass/shutoff valve to heater core MAT relocated Ram-Air(home-made) gutted air-box IROC ground effects/wheels GY245/50's 700R4 superior shift kit/ corvette servo(excellent shift kit BTW) Rebuilt engine and transplanted it myself. Love this engine!
LOW performance people should drive low performance vehicles!
Wade787b
Sep 29, 2015 01:15 PM
TreDeClaw
Aug 14, 2015 06:58 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
