what the heck it thins????
can someone tell me what this is its not connected to anything, on the end of it is a loop thing that looks like something that would connect to my cab???
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Thats not the detent cable, its the cruise control cable. Its not that important, just that the cruise control won't work without it hooked up. Your holley carb most likely doesn't even have a place to connect it to.
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
might havta go with ward on this one.. really hard to tell from the pic tho.. just make sure theres a detent cable hooked up to your carb under the throttle linkage
Car: 1988 GTA
Engine: 5.0 TPI
Im sure its the cruise control cable. In the 2nd pic, you can kinda see the end of the cable, its got a long slotted hole, and also a long plastic sleeve covering the cable itself. The detent cable has neither of these.
Car: 1989 C4
Axle/Gears: 307
You can kinda see the end in the one pic slotted & long. Its either a dentent for a TH350 or cruise. What kind of transmission is in the car? If it was a detent for a 700r4 you would know when the car wouldent shift that something got misplaced
TH 350 doesent need it but its nice to have things working if thier there ya know.
I don't feel like posting these pictures twice...
https://www.thirdgen.org/techbb2/sho...hreadid=186399
ah that must be it, im thinkin of a 350 tv cable.. never seen one for a 700
This thread has a good picture of one. It's in the first post with pics, the little black connector.
