hey how can i bypass VATS on a 90 IROCZ.
Old Jun 19, 2003 | 08:10 PM
FbodiesOnly's Avatar
How hard is it to bypass VATS?
Old Jun 19, 2003 | 08:29 PM
prOject-IrOc's Avatar
Car: 1990 Iroc-Z
VATS bypass kit ($25)
not sure on the procedure, or difficulty. i spent a $100 on a new key cause my chip fell out of my key. i think it was worth it though, knowing that my car cant be hot wired. my car has been broken in to at least 5 times. thank *** for vats.
Old Jun 19, 2003 | 08:57 PM
yeah i got a new key cut from gm. still has probablem starting my brother wants to just bypass VATS.its been having serious problems with it.ur car should be fast in the 1/4mile my brothers 90irocz runs 14.2's stock.with 155k.5.7 tpi,with 3.42 gears.
Old Jun 19, 2003 | 08:58 PM
also forgot to ask where can i get a bypass kit?
Old Jun 19, 2003 | 09:10 PM
Car: 1990 Iroc-Z
that sounds very nice. unfortunately, i have been having ALOT of problems with a transmission that I JUST PUT IN! Hopefully, whenever i get a working tranny i will take it down and give it a run. i'll be happy if i can squeeze into 13's.
you said you have been having alot of problems starting it...does it turn over? if not, i would check the neutral safety switch. for a loooong time, whenever my car would get hot, it wouldn't start. no cranking, nothing. i checked everything. changed the starter 3 different times, and it still did the same thing. it would start fine 1 minute, leave me stranded the next. finally one day when i was waiting for it to start again, i leaned on the gear shifter while i was turning the key, and VRRUMM!! I was like, WTF?!?! So i turned it off and messed around with the gear shifter, and finally figured out it was my Neutral Safety Switch. very easy fix, but spent alot of money fixing things that werent messed up. hope this helps..
oh and i think you can get the vats bypass at jegs or summit.
Old Jun 20, 2003 | 12:25 AM
the car would be really hot it will start.it can be cold it wont start.its like it can happen anytime.also the car doesnt crank at all when u turn the key its like its not even try to start the car.but my brother getting really aggervated.we disconnected the battery and reconnected it started back up.i dont know whats going on.
Old Jun 20, 2003 | 07:23 PM
Car: 1990 Iroc-Z
yah i would definately check the Neutrak safety switch...sometimes even if the car wasn't driven, it would just not start. no cranking or nothing. just try pulling the gear shifter down a lil bit while you are turning the key. kinda like you are trying to put it in reverse. if that doesn't help, i'd check the wiring to your starter. maybe solenoid is going out? i dunno. hope he gets it fixed. keep us posted.
Old Jun 20, 2003 | 09:04 PM
ronterry's Avatar
Car: '94 Corvette
I might be wrong on the 3rd gen, but the Vette Passkey bypass requires you to know the key code. Usually it's a number between 1-15??? and those are assigned by the specific ohm rating of the resistor pellet in the key.
Someone here will have to post the list of code numbers. because I don't have them...or you can bring your key to the dealership, and they will tell you what code you have.
I did it with my Vette just in case my keys die, or gets lost...
Ron
Old Jun 20, 2003 | 09:08 PM
Car: 1990 Iroc-Z
Ron
you are correct..
Old Jun 20, 2003 | 11:59 PM
yeah gm cut up a new vats key for it.
Old Jul 10, 2003 | 10:58 PM
brig's Avatar
A locksmith will be able to check the code on the key.
I was having a problem with the car not starting it was getting worse. I brought it to a mechanic and he charged me only 75.00 to bypass. Well worth it.
Old Nov 17, 2004 | 05:16 PM
Calico's Avatar
Car: 1985 Buick Regal T
Engine: 87 3.8 turbo/lc2 drive train
Transmission: 200r4brf
how did he bypass it?
Old Nov 17, 2004 | 06:21 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
We're skirting the bounds of getting into legal issues here.
Let's just say do a search and leave it at that. Anything that has been allowed to live is all we're going to allow to be posted on the Board. Having a legally-obtained key is the most important factor. Outside of that, there is no reason to continue discussing it with this thread.
IROCtometal
Sep 9, 2015 10:01 AM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
Jk_Under
Sep 8, 2015 08:13 AM
90formulaVortec
Sep 3, 2015 09:26 AM
Jackrabbit501
Sep 2, 2015 09:14 PM
