Turn Signals...
Old Sep 30, 2000 | 12:37 PM
MrYenko's Avatar
Turn Signals...
Ok...I had a small problem with the left hand turn signals on my 87 Camaro...I checked the bulbs, and one was blown (Front Signal in the fascia under the headlights), so I replaced it, but still nothing. The 4 way flashers are the only way to get the bulb to light. The other lights on the left all work, but when the signal arm is depressed, there is no clicking, they just stay on. Also, the indicator light for the left hand signals stays on whenever the parking lights or headlights are on...Is this a problem with the flasher unit in the column? or is it a sneak circuit somewhere?
If it moves, kill it. If it doesnt move, wait for it to move, THEN kill it.
Old Sep 30, 2000 | 12:41 PM
Vader's Avatar
Mr. Yenko,
Check the ground connections at the turn signal lamps, both front and rear. Typically, "wierd" problems like the indicator on the dash lighting happen when something in the circuit has a less than perfect ground connection.
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
gta892000
Aug 11, 2019 11:16 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
bbsr72
Sep 27, 2015 05:55 AM
greenyone
Sep 8, 2015 08:41 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
