Need help on 3800 motor
Old Sep 30, 2000 | 12:05 AM
foo02's Avatar
I have a 92' bonneville that was missing on a cylinder(see earlier post) and i also have a 92' buick regal with a blown 3.8 in it as a parts car. The bonneville needed a coil pack and the regal, altho the motor looked exactly the same, had a different coil pack
it had one with all the plug wire terminals in a straight line, the bonneville had 3 on each side style one. I put the one off of the regal on the bonneville, and it seems to run fine, but my question is 1)will it hurt anything switching kinds of coil packs and 2)what is the difference?
Any help is appreciated.
~Sp33d~
(sold)1989 2.8l 5-speed RedBird w/ flowmaster, cold air intake, TRW cam. Audio system includes-Cadence component plate 4x6's/Cadence 3way 6x9's,300watt amp to front speakers/400watt to Blaupunkt DVC 12" sub.
Old Sep 30, 2000 | 07:14 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
In order for you to have done that, you also swapped the ignition module also, becuase the different coils require a different module. They operate basicly the same, however the Type II (delco) are more efficient and powerfull then the Type I (magnavox) that you just put on. Will it hurt? Not really, since they operate about the same, it would be like replacing an LS1 with an LT1 (except the horsepower). In otherwords, you downgraded your ignition system to a lesser style, but should function about the same. (just remember what car the parts came off of when you go to buy new ones)
If you live in Southeastern US, check us out!
South East Thirdgen
"I used to have a handle on life, but then I used it as a plunger and broke it" -The Wave
ASE Master Tech + L1
Savannah, GA
'87 Trans Am-K&N,Cold air induction, SSM SFC, Boxed LCAs, 8mm Accel wires, Flowmaster, 16" GTA rims.
'97 Bonneville SSE
hydrolic144
Sep 8, 2015 06:55 PM
masonta
Sep 1, 2015 06:40 PM
greenyone
Aug 29, 2015 11:08 AM
Randomtask2
Aug 26, 2015 03:34 PM
slade5612
Aug 11, 2015 07:19 PM
