Big Gains With New Camshaft Only???
Old Sep 30, 2000 | 07:48 PM
88 IROC BOB's Avatar
Would just replacing the cam with a good aftermarket one without changing heads or intake components be worthwhile? I'd like to do a complete rebuild (boring, new cam, heads etc.) but its not in the budget for at least a year or two. Any opinions are welcomed.
Bob
350 TPI, 700R4(rebuilt), K&N's, MSD 6AL, Headers, Flowmaster, 160* stat, airfoil, MAF screens cut out. 13.88 @ 101.18 mph
Old Sep 30, 2000 | 07:58 PM
CamaroX84's Avatar
It should be a big improvement if you select the right cam for your heads, valve springs, etc. A new cam that is not matched isn't going to help you that much, but if you select the right one, I have heard up people gaining between 30 and 40 horsepower just from a cam swap. You also might want to consider a new timing chain with the cam as well. Hope this helps.
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
3.8TransAM
Oct 1, 2015 07:47 PM
82xCAMAROxZ28
Sep 27, 2015 12:31 AM
