Ticking noise from motor
Old Sep 29, 2000 | 06:43 PM
88irocz28's Avatar
Car: 1994 Trans Am
Engine: 5.7L LT1
Transmission: 6-speed
My 305 TPI makes this ticking noise all the time regardless of engine temp. It doesn't get any louder or quieter, it's just there. The noise has been there ever since I bought the car in Oct 99. I always thought it was the distributor, but earlier posts concerning rod knock and lifter noise on this board have me a bit worried. I thought it was the distributor or valve train, because thats what all my other cars, albiet 4 bangers, did. The noise from the distributor didn't cahnge with temp but the noise from the valve train went away as the engine warmed up.
Any ideas or suggestions anyone? Could probably be the injectors I think. The ticking sounds real harmless, no problems with engine operation.
'88 IROC 305 TPI
Gutted airboxes
160 degree T-stat
Advanced base TPS voltage
Relocated IAT sensor
Momo steering wheel
Ram-air setup coming soon
Flowmaster muffler
Old Sep 29, 2000 | 06:52 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
It is a bomb.
No, the TPI injectors WILL make a ticking sound. It does sound similar to a loose rocker (weak lifter), but it is definitely at the top of the engine and does not get louder as your rev it (like a rocker/lifter will). Also, you will hear it from both sides of the engine, not just one side or one side being distinguishably louder.
A lifter also sounds like it is coming from the "heart of the engine", not the top.
Hope this helps.
Old Sep 29, 2000 | 07:46 PM
MIKES 88GTA's Avatar
is the injector tick bad? mine does it also and when I pulled them out the gunk build up on the inside wasn't even, or even looked the same on any injector.Is this bad?
Old Sep 29, 2000 | 09:47 PM
Allan's Avatar
Car: 1988 IROC-Z
Engine: 5.7L TPI
Axle/Gears: BW 2.77
Injector ticks are fairly loud. Sounds like injectors to me too. Not loud, just ticking ... i believe the stock injectors are normally loud.
Old Sep 30, 2000 | 08:05 PM
88irocz28's Avatar
Car: 1994 Trans Am
Engine: 5.7L LT1
Yeah the ticking seems to come from the top of the motor and from both sides.
'88 IROC 305 TPI
Gutted airboxes
160 degree T-stat
Momo steering wheel
Flowmaster muffler
theshackle
Sep 17, 2020 08:26 AM
xxx3man`
Sep 23, 2015 10:37 PM
db057
Sep 4, 2015 07:57 AM
B_Dubya
Aug 26, 2015 05:09 PM
redmaroz
Aug 16, 2015 11:40 PM
