possible to make 420+ HP 383
Old Jun 27, 2003 | 10:15 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
i want to build a 420+ hp motor but i need to do it w/a small block. is it possible to take a 350 or 383 short block bottom end and make 420 hp with it with a cam, heads, and my TPI intake????
Old Jun 27, 2003 | 10:20 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
No.
However it would be easy with some other induction system.
Old Jun 27, 2003 | 10:21 AM
1986redbird's Avatar
it's possible to make more power than that with the right combo, however, you can't just slap parts together and expect them to work the best, they need to matched to each other for the best performance. I don't think you'll see that much H.P. using a TPI setup, the way they are tuned limits them to about 4500 RPM max. if you use a mini-ram or super-ram then it's more than possible.
just remember this simple equation H.P. = $$$$$$$.$$
Old Jun 27, 2003 | 07:48 PM
SSBlueOx's Avatar
Car: Camaro RS
Engine: 305ci TBI
Transmission: TH-700R4
Couldnt have said it better. IMHO i would go carb cuz of the cheapness of the carb induction compared to the Stealthram/superrams.
SSBO
Old Jun 28, 2003 | 01:49 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
If you want over 300hp, dump the TPI... its the performance equivalent of asthma
Put on a 4bbl and it will make as much power as you could ever want.
gixxer92
Sep 1, 2015 04:32 PM
lt1z350
Aug 28, 2015 05:57 AM
86White_T/A305
Aug 17, 2015 12:16 AM
sreZ28
Aug 14, 2015 07:48 PM
85Iroc-Z
Aug 13, 2015 01:58 AM
