how do i position the dist. when putting new engine together.....nm
Old Oct 1, 2000 | 02:22 PM
ckcam310's Avatar
trying to get engine back together....do i put the piston tdc or what
Old Oct 1, 2000 | 02:56 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
1. Find #1 firing by compression: put your thumb over the hole while somebody bumps the starter, or put a piece of fuel line in the hole and listen for it, etc.
2. Leave the motor at about 12° BTDC of #1 firing.
3. Turn the oil pump rod about 30° away from straight front-to-rear, going from right rear to left front.
4. Hold the distributor in the position it will go in when it's in there; if you have the older large one, that will be with the batt & tach terminals directly to the driver's side, if it's the newer small one, the flat side of the dist housing will go straight to the driver's side.
5. Rotate the shaft so the rotor points about 20° toward the front of straight to the driver's side.
6. Drop it in. The rotor will turn CW as it drops in. It should end up approximately 22½° to the driver's side of straight ahead. Put the cap on, and the plug wires on it; #1 will be just to the left of straight ahead, the rest will go around the cap CW in the firing order (18436572)
7. Hook up the primary wires.
8. Reach in the window and crank it up. The timing should be somewhere between 6 and 10° BTDC, which is near where you want it.
apo_bailon15
Mar 28, 2016 05:20 AM
Jae992
Aug 27, 2015 09:07 AM
db057
Aug 22, 2015 08:17 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
