Where's the crank snout?
Old Oct 1, 2000 | 08:12 PM
crazeinc's Avatar
My buddy said I can check to see if I have a steel or cast crank if I look at the crank snout to see whether the forging line is either 1in wide or a small line maybe a 1/16 wide
82 Z28
355 carb'd, Edelbrock Performer RPM package (minus heads), Hooker Super Comps, Mufflex 4" offroad y-pipe, 700r4 with B&M shiftkit, '85 IROC 10 bolt rear with Richmond 4.10's & Auburn posi unit, Lakewood 50/50 drag shocks. Shooting for 3000lbs w/ driver.
The car's website (New design in progress...very cool look)
(383/TH350 buildup this winter)
AIM: Unitedhope
ICQ: 77979548
Old Oct 1, 2000 | 08:20 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
If the engine is in the car, you need to pull the flexplate cover off and look up at the rear of the crank.
Roate it around to the flat part of the crankshaft, you should be able to see the casting flash.
If it is on a stand then just look at the rear of the crank, you will see where it was "cast"
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
GO #3
[This message has been edited by Engineboy (edited October 01, 2000).]
Old Oct 1, 2000 | 08:34 PM
crazeinc's Avatar
Thanks engineboy...just checked it (it's on a stand)... cast crank oh well...what are the chances were it of actually being steel?
Old Oct 1, 2000 | 08:44 PM
Vader's Avatar
Craze,
Don't give up yet. It might be a cast steel crank or nodular iron crank. You can still use a cast crank up to 400-450 BHP, but it gets iffy at higher RPMs.
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
Falcon50
Aug 22, 2020 03:26 PM
RS Reaper
Oct 17, 2018 07:52 PM
skinny z
Oct 5, 2015 06:23 PM
anesthes
Sep 30, 2015 07:48 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
