Performance Addon Suggestions For 82-Z
Old Oct 1, 2000 | 10:49 PM
nesluopetan's Avatar
Im just running out of ideas here for my 82 Z28 Crossfire 5.0 Litre.. this is what I do have on it now..
Edelbrock TES Headers
Supercoil
Flowmaster 80 Series
Flex Fan
Shift Kit
I know its not much, but its hard when your 16 years old.. :-( I would just like some ideas on how to get more performance, speed wise, and sound/looks wise.. Please help if you can. thanks alot! You can see A couple pictures of my car on my sucky site.. www.bigfella.net thanks.. also, if you are a techie person, please reply to my other topic .
Old Oct 2, 2000 | 12:29 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
A distributor rebuild might help things... they're not hard to do.
Also, what about making your own ram-air intake? It's been a while since I've seen a CFI motor, but I don't think their intake hoses left the engine compartment.
I'm sure somebody makes a set of underdrive pullies for your car.. some guys like 'em, some say they don't notice a difference.
You could also try a computer chip, or if you want to save the $$, I'd assume you could advance your timing a few degrees. (Which goes along with rebuilding the distributor.)
If you know your rear gear ratio, and it's numerically lower than 3.42, you can go to the junkyards and look under some mid-eighties 2.8 v6 cars. They usually came with a 3.42 axle, an open diff, and drum brakes.
Keep in mind that your '82 car uses non-metric (SAE) brake line fittings. So if you get, say, an axle from an '87, you'll have to unbolt -your- drum brakes from -your- axle, and put the assemblies onto the '87 axle. Either that, or you'd have to hunt down the correct adapter fittings, which ain't fun.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
Old Oct 2, 2000 | 03:00 PM
CrossfireCamaro's Avatar
Arrrgghh I used the wrong password, and when I hit back my post went bye bye
Anyways, a good place to start would be the porting of your intake manifold, asuming you have the time, tools, experiance and help. Considering you already have some exhaust mods this should help alot, and should be reletivly cheap if you do it yourself. Another free mod is the removal or modification to the mixture plates below each TB, both of the above mods should increase your midrange and topend, with vitualy no lowend loss. Past this point things start to cost money, such as roller rockers, heads, cam, possibly a 350, ECM, gears, etc. For more information on porting your manifold or modifying the mixture plates visit this website http://www.crossfire.homeip.net/ There are a number of people there who have done these mods and will happily share tips ideas etc. Just search through the forums and FAQ there and you should find any informatin you need to get going, and if not feel free to ask.
Veaceonee
Sep 29, 2016 08:15 PM
R13_Braz
Sep 18, 2015 05:00 PM
64goatman
Sep 9, 2015 01:09 PM
Jk_Under
Sep 8, 2015 08:13 AM
scottmoyer
Sep 7, 2015 07:06 PM
