What you heat range plug's are you guy's running?
Old Sep 18, 2000 | 06:47 AM
BLACK Z's Avatar
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
I am runnig rapid fires I think number 2's, could you tell me what heat range they are? and I am also wondering what you guy's are running. And also could the wrong heat range make you pop thought the exaust on decell?What motor do you have?
86Z28, GM 350, Jet perf Q-jet & chip Dual snorkel air cleaner, Edelbrock performer intake, Edelbrock headers, Edelbrock cat-back, Off road pipe, MSD 6AL, Accel Super Coil, Moroso Blue max wires, Rapid fire plugs, Jet fan switch, World class t-5, Hurst Short Throw Shifter, Ram Flywheel, Center force dual friction clutch,Aluminum drive shaft, BW disc rear 3.45's & a posi, PBR calipers, Earls braided brake lines, Polygrapite bushings all the way around, poly tranny mount & torque arm mount, Hotchkis lower control arms & panhard rod, Rancho limiter straps, KYB struts & shocks, Gm Wonderbar, Edelbrock strut tower brace, SSM sub frame connectors, Jamex lowering springs, Carbon metallic brake pads, Crossed drilled rotors, Mobil 1 Tranny fluid & motor oil, GM syntheic rear end oil, K&N, Grant stering wheel, 1,200 watt system, Jet Black Paint, 91 Z28 rims, 92 wing, Tinted windows.
Old Sep 18, 2000 | 08:48 PM
Vader's Avatar
Champion 15s
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
Old Sep 19, 2000 | 06:40 AM
BLACK Z's Avatar
Car: 86 Z28
How would that compare to ac's
Old Sep 19, 2000 | 12:34 PM
Vader's Avatar
I'm not positive, but I thinki it's the same range as an AC 45.
Later,
Vader
"Make Me Bad"
Old Sep 21, 2000 | 09:22 PM
BLACK Z's Avatar
Car: 86 Z28
No one else uses spark plug I guess. Just playing,
Old Sep 21, 2000 | 10:20 PM
S92RS's Avatar
I was running regular AC Delco R43TS's but I think they were a too little cold so now I put some R45TS's in.
- the 92 RS is gone..
- 1984 Z28 with 89 bumpers and ground effects.
- 355 with ported World S/R Torquer Heads, 214*/224* .471/.496 lift cam, Crane 1.6 Full Roller Rockers, 2500 non-lockup stall converter, Holley 750 carb, Edelbrock Performer intake, Hedman headers with custom 3" Flowmaster exhaust, Lakewood LCAs, Powertrax Locker with 3.23 gears.
- http://s84z28.fbody.com
Old Sep 24, 2000 | 10:25 AM
BLACK Z's Avatar
Car: 86 Z28
thanks anyone else.
Old Sep 24, 2000 | 12:40 PM
raven350's Avatar
Car: '89 Pontiac Firebird
Engine: 5.7L
Axle/Gears: 10-bolt w/ 4.10 and Eaton Posi
I am running AC Declo R43TS's....
Sportsman II 72 CC heads, Pete Jackson gear drive, Performance Resources chip, Edelbrock 1 5/8" headers and Edelbrock cat back exhaust, hi-flow cats, Trans-go stage 3 shift kit, Vigilante 9.5" 2800 stall convertor, SLP cold air induction, SLP roller camshaft, 24lb ADS injectors, AFPR, 3.45 rear end gears, and other goodies...
http://members.aol.com/jwnolte/raven.htm
Old Sep 24, 2000 | 02:49 PM
Allan's Avatar
Car: 1988 IROC-Z
Engine: 5.7L TPI
Axle/Gears: BW 2.77
45's here. Before I was using flint.
Old Oct 2, 2000 | 06:48 AM
BLACK Z's Avatar
Car: 86 Z28
Flint works well execpt when it is raining.
Old Oct 2, 2000 | 11:03 PM
CamaroZ_85's Avatar
I was running 45's but now have 44's cause i was getting bad detonation...figured maybe goin a little colder would help...
350, Comp 262, Edelbrock Performer intake 600 cfm carb and exhaust, headers
theshackle
Sep 17, 2020 08:26 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Jae992
Aug 27, 2015 09:07 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
