Accidently shifted into drive at 5500 RPMS
Old Oct 2, 2000 | 12:01 AM
Brandog87GTA's Avatar
I was racing and thought I was in D instead of OD, well I shifted into neutral and then back into drive tached out. Now my shifts are not as firm, and it shifts funny into 3rd gear.Could I have ****ed something up? I have a shift kit so it should be shifting hard, now it shifts soft as hell, and my shift points are sooner than usual. I was doing about 70 MPH.
Bright red 87 GTA with 350 tuneport. Basic mods such as K&N filter, Flowmasters, Wells MAF, TPIS air foil, Accel 8.8mm plug wires with Bosch platinum plugs, Accel distributor cap and rotary buttons.Gutted cat. Hope to port runners and plenum in about 2 weeks.
Old Oct 2, 2000 | 12:12 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Now -there's- a reason to get a B&M megashifter!
Your TV cable might've slipped out of alignment. (Don't know how you would've caused it at that moment, but...) The TV cable adjustment usually slips too far forward, which will give you an earlier and softer shift. The reset procedures should be in the shift kit's instructions.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
Old Oct 2, 2000 | 02:46 PM
I will try to adjust it and see if that helps, thanks for the input.
Bright red 87 GTA with 350 tuneport. Basic mods such as K&N filter, Flowmasters, Wells MAF, TPIS air foil, Accel 8.8mm plug wires with , Accel distributor cap and rotary buttons.Gutted cat. B&M Shift kit, 100HP shot Nitrous, soon to change over to carburator.
Old Oct 2, 2000 | 09:54 PM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
it is possible you may have messed something up. did you let up before you put it back into gear? might be good time for megashifter or just get smart and put in a governer to make the trans shift when you want it to in drive. just because you can shift it manually doesn't mean you have to. not like you have a drag car.
Old Oct 3, 2000 | 03:45 PM
branz28's Avatar
Car: 1989 IROC-Z
Engine: 383
Transmission: Pro-Built 700R4 2400 ACT Stall
Axle/Gears: 2.77 Borg Warner 9-Bolt
I agree with zippy, but personally i'd get me a different shifter and then have a tranny specialist take a look at it. I live in Chester, Illinois and there is a guy that will test and adjust your tranny for free, but if anything requires a wrench being picked up and something taken off its some money. So if it doesn't work after the adjustment take it to someone who deals with the stuff. Thats just what i'd do.
I myself have the manual shift stuff, where if i'm doing 120 in OD and shift into 1st, mines in 1st gear...but my tranny is built up with transgo and borgwarner **** so it ain't gonna hurt nothing. no good for the engine but well, i don't plan on manually shifting either, OD is good enough for me...
89 IROC-Z 350 TPI
-Flowmaster Catback
-Performance Resource Chip
-Rebuilt 700R4 Tranny
With the goodies to go
-K&N Airfilters
-Ported Plenum
-2.77 Gears (not much to brag about but eh, its there)
Old Oct 3, 2000 | 05:14 PM
scoob8000's Avatar
Car: 95 Caprice
Engine: 5.7l LT1
Axle/Gears: 2.93
why do people drive their slushbox like a stick then wonder why its failing? if you wanna manually shift, get a manual tranny, if you burn up a clutch at least you dont have to rebuild the entire tranny...
Old Oct 3, 2000 | 09:16 PM
zippy's Avatar
Engine: 5.3L
it's not like it's going to kill it to be manually shifted, but there is no point in it for a low rpm engine like that. people that have true race cars with auto's use manual valve bodies becuase there is no governer to shift at over 7k. but for something that shifts in the 5k range, there is no reason to not set it up to shift at your chosen rpm other than an excuse if you lost that you didn't manually shift it.
jklein337
Sep 19, 2018 06:23 PM
Streetstuff
Carburetors
Sep 7, 2015 02:33 PM
kyleb24
Aug 15, 2015 08:24 AM
dhonda200
Aug 11, 2015 11:50 PM
