Oil smells like Fuel? This can't be good...
Old Jul 2, 2003 | 05:56 AM
prOject-IrOc's Avatar
Car: 1990 Iroc-Z
Ok, so we start to pull the tranny back off tonight to send back to florida so the shop can see what they did wrong the first time (damn ebay), but anyways, i decide to check my oil, and it smells like gas. pretty strong....
what "could" this be?
Old Jul 2, 2003 | 06:01 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
running rich....Blow-by...old motor?
Old Jul 2, 2003 | 06:25 AM
Car: 1990 Iroc-Z
car and motor in sig....
no oil in the intake, jus alot of carbon.
Old Jul 2, 2003 | 09:44 AM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
bad rings possibly...
Old Jul 2, 2003 | 10:08 AM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
a ruptured FPR will cause this and is all to common a result. check there first. secondly it could also be a sticking bad injector(s). fix it asap. fuel dilutes oil. that will lead to mechanical problems with your motor. ie fuel washes the cylinder walls and/or ruin the bearings, if enough fuel gets into the oil.
Old Jul 2, 2003 | 03:32 PM
Car: 1990 Iroc-Z
how could i tell if it is from a fuel injector?
or the FPR (fuel pressure regulator)?
Old Jul 2, 2003 | 05:29 PM
Car: 1988 IROC-Z
usually the vacuum line coming from the fpr has fuel in it. in my case the line was full of gas . if you have a FP guage you can use that to see if pressure is being bled off after the engine is primed. more than likely it will be. as for the injectors that's a little harder. the best way but most difficult is the remove the rail, while the injectors are still on the rail, and prime it. leaking injectors are easily identified this way.
Old Jul 2, 2003 | 05:49 PM
RJR99SS's Avatar
The most likely cause is that you drive it only on short trips. You dont let the engine heat up to normal operating temperature before you shut it off basically.
IF that's not the case, then see above.
Old Jul 2, 2003 | 07:04 PM
Car: 1990 Iroc-Z
sorry guys, i don't know much about the fuel system, what does the fpr look like?
a friend of mine said that he had an old escort, and the oil smelt really bad like fuel, and he ended up having a cracked block?!?!
anyone else heard of that?
anyways, i hope you guys are right and it just an injector or the fpr.
maroe624
Apr 16, 2017 08:29 AM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
Navy8125
Aug 21, 2015 09:32 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
