Fuel/several cranks till it fires
Old Jul 2, 2003 | 09:52 AM
JCee's Avatar
1988 5.7 ...170K miles
Takes several cranks - like 5+ - when sits over night to fire up.
Can hear fuel pump is powrd up in "on" position - relay has been changed; fuel pump replaced about 3 years ago.
Any advice would be helpful
Old Jul 2, 2003 | 02:32 PM
felo72's Avatar
Change fuel filter, cap, rotor, plugs, and wires. If that still doesn't cure the problem, check your timing, the TPS, and the IAC.
Old Jul 2, 2003 | 02:54 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
before you spend money, check your timing.
heh, its funny, but its like the most common thing ive been saying on the board..
overheating? check your timing
hard starting? check your timing
detonation? check your timing..
and then ive been gettin PMs saying thanks... it was my timing.
not saying that it is in your case, but its quick and easy to check...
Old Jul 3, 2003 | 07:03 PM
joshwilson3's Avatar
Old Jul 3, 2003 | 10:07 PM
Guest
Guest
Posts: n/a
shouldn't it be more like
I get pinging noise in my motor any idea why?
A) check the timeing befor you blow a hole in your piston
later reply) to late it already happen... i didn't know timeing could do that
haveing your car out of timeing can make you lose power or get more power but somethings more is a bad thing.
Old Jul 5, 2003 | 08:51 AM
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
KCG
Jun 24, 2020 04:33 AM
camarohelp
Sep 22, 2015 03:19 PM
89bird2.8
Sep 18, 2015 07:46 PM
Stroopwafel
Sep 11, 2015 06:38 AM
