BLACK SMOKE ?? HELP????!?!!?!?! head gasket
Old Jul 2, 2003 | 05:52 PM
JMONEYTREE's Avatar
Car: 91 Camaro
I noticed today that I have black smoke coming from my tailpipes at startup. It only happens after the car has been sitting for awhile. Its a 91 Camaro RS with a 305 TBI. Could this be a head gasket ? Please help!!!!!!!
Old Jul 2, 2003 | 06:02 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Exhaust smoke color generalities:
Black = excessive fuel
Blue = oil in the combustion chamber
White = coolant in the combustion chamber.
A bad gasket causing smoke is generally leaking coolant, and makes white smoke. Since you say it is black, I'd suspect you've got a leaking injector. If in fact it is really bluish rather than black, that's valve stem seals gone bad, which is quite common with our cars.
Old Jul 2, 2003 | 06:29 PM
JMONEYTREE's Avatar
Car: 91 Camaro
Black Smoke
Its Throttle Body Injected TBI. Could this still be the injectors ? This is a mint conditon camaro. Very rare in the area. If it is the valve seals, how much will this be to fix ? thanks
1992 Trans Am
May 10, 2023 07:19 PM
Red iroc-z 305
Sep 30, 2015 05:22 PM
NinjaNife
Aug 23, 2015 11:49 AM
qz6lwp
Aug 20, 2015 08:10 PM
