Vaccuum help ???
Old Jul 2, 2003 | 09:05 PM
david roush's Avatar
Car: 92'Camaro RS
Engine: a loud one
Transmission: bolted to the engine
Vaccuum help ???
I think i have found the last problem in a tune port swap. Got the car running alright but it lacks pick up on acceleration. Feels like a vaccuum problem . When i was setting the idle screw i noticed what seems like a vaccuum line i have overlooked. It's a small inlet coming out of the underneath the throttle body closer to the drivers side.. Anyone know if this is a vaccuum line, and where it connects to ?
Old Jul 2, 2003 | 09:58 PM
prOject-IrOc's Avatar
Car: 1990 Iroc-Z
that sounds like the "tb coolant bypass" valve. you should have one on the passenger side of the tb that pumps water in, and the one on the passenger side is where it comes out. if you don't live where there is freezing weather, you can just bypass it. there is a link on the thirdgen page on how to do the tb bypass. i have it done to my car. you can blow into one hole and feel the air come out the other...
hope this helps.
Old Jul 2, 2003 | 10:16 PM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
If it is just a tiny vac tube, like as in maybe 1/4" it goes to the EGR soleniod, or it should, and yes this could cause some performance problems, the Tb coolant tube is about 3/4 inch in diameter to give you the difference of the two sizes.
Old Jul 2, 2003 | 10:21 PM
Car: 92'Camaro RS
Engine: a loud one
yea...it's real tiny......underneath the throttle body....not the three outlets that come out the passangers side of the throttle body.. i have those three figured out.
Old Jul 2, 2003 | 10:25 PM
Cruzin Kaz's Avatar
Engine: T.P.I L98.
Transmission: TH350
OK then, that one goes to one of the two Vac hoses that go to the EGR solenoid by the distributor (passenger side), the second hose on the EGR solenoid goes to the EGR valve itself. With this not working properly it will cause performance issues.
Old Jul 2, 2003 | 10:29 PM
Car: 92'Camaro RS
Engine: a loud one
cool...thanks .....i think that's it...i'll try it tomorrow and see if it runs any better.
Old Jul 2, 2003 | 10:31 PM
Cruzin Kaz's Avatar
Engine: T.P.I L98.
Transmission: TH350
Your welcome, let me know how it goes.
Old Jul 2, 2003 | 10:52 PM
Car: 1990 Iroc-Z
Jerzyperson
Carburetors
Nov 13, 2015 01:07 AM
timonator
Sep 30, 2015 12:52 PM
ChevyKen
Apr 14, 2002 09:23 AM
KeithO
Jul 24, 2001 06:20 AM
