How do I make my car shift at more than 4000?
Old Oct 2, 2000 | 10:03 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Floored it shifts at 4000 how do i get it up to 5000?
Old Oct 2, 2000 | 10:08 PM
new87's Avatar
Car: 87Z
Engine: ?
Transmission: A4
What do you got my car does shif till about 5500 read the sig thats all its got.
87 Z28 305 TPI, Auto, Gutted air boxes, K & N fillters, Dyno Max 3" cat back.
Old Oct 2, 2000 | 10:13 PM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
if your throttle valve cable is adjusted properly and it shifts there, you need a different governer. it controls your shift points.
Old Oct 3, 2000 | 01:18 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Everything is set properly. I got a 350 TPI Full exhaust shiftkit top of line ignition pulleys ported intake and other stuff.
Old Oct 3, 2000 | 02:08 PM
87Iroc-z's Avatar
Car: 1987 Z28
Transmission: 700-R4
Hey Matt,
I see your still trying to mess with those shift points. I bet your itchin to get that car in the 13's after the run you made Sunday.
Old Oct 3, 2000 | 02:55 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Have you verified that your tach is accurate? Mine seems to be off by as much as 25%!!!! According to my tach, mine shifts at 6k, but I replaced the governor and the TV cable with the same results. I tried to watch my speed when it shifted, and after I ran it through the proper RPM calculations, I came up with 4700, right where it should be.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Oct 3, 2000 | 04:22 PM
Auggie's Avatar
Car: 1984 Z28 Camaro
Engine: H.O. 355 NOS
Mkos1080, mabey someone could help you if we knew what kind of trans you had.
-Auggie-
Old Oct 3, 2000 | 06:31 PM
Jim85IROC's Avatar
I'm guessing he's got a 700, because if the T5 is shifting itself at 4k you better call an exorcist.
The IROC Homepage
Old Oct 3, 2000 | 10:18 PM
branz28's Avatar
Car: 1989 IROC-Z
Engine: 383
Transmission: Pro-Built 700R4 2400 ACT Stall
Axle/Gears: 2.77 Borg Warner 9-Bolt
LOL! Sorry, but i had to reply...
I have a 350 TPI and umm, mine shifts at 5,500 rpms... Then again i have a new tranny that wasn't installed by me maybe your TV cable needs to be adjusted?
89 IROC-Z 350 TPI
-Flowmaster Catback
-Performance Resource Chip
-Rebuilt 700R4 Tranny
With the goodies to go
-K&N Airfilters
-Ported Plenum
-2.77 Gears (not much to brag about but eh, its there)
Old Oct 3, 2000 | 10:20 PM
Auggie's Avatar
Well, if he has a 700R4 all he has to do is call B&M and buy a govener Shift Point Kit #20236 and follow the instructions. This kit will work on the TH-350, TH-400 and the 700R4.
Good Luck.
-Auggie-
Old Oct 4, 2000 | 07:49 AM
Jim85IROC's Avatar
It doesn't necessarily have to be an issue with a governor, and using that to compensate for a different problem isn't smart. He needs to find out what the problem is first.
The IROC Homepage
Old Oct 4, 2000 | 10:00 AM
Auggie's Avatar
Well, when he said that everything was adj. properly (post 10/3 11;18) and he has a shift kit the only other easy way to change shift points is to change the weights or springs in the governor. If that sounds stupid i'am sorry but i have done it many times with great sucess. I assumed that after he installed the shift kit the trans shifted ok or he would of mentioned it. Oh, and i had my tach checked with a scan tool and it reads 250 rpm high. This method would be more accurete. Just my .02
-Auggie-
Old Oct 4, 2000 | 02:27 PM
Jim85IROC's Avatar
He still hasn't even said whether he has checked his tach or not. Our stock tachs are NOT accurate at all.
IF everything else is operational, then I would also suggest that the governor is where to look at, but I know from my own personal experience that sometimes changing the governor doesn't help jack ****.
The IROC Homepage
Old Oct 4, 2000 | 10:24 PM
Auggie's Avatar
Jim, i didn't say anything about changing the govenor (HIC HIC) i said that he should change the gov. weights or springs (HIC HIC just got back from golf) on his gov. I mean you can do this mod and get within 50 rpm of your desired shift point. Vader do you have any imput???
-Auggie-
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
mizz0313
Aug 12, 2015 06:45 AM
dhonda200
Aug 11, 2015 11:50 PM
Exxon Limited
Aug 9, 2015 08:13 PM
