what is the best fuel filter for 305 V8?
Old Jul 3, 2003 | 07:01 PM
joshwilson3's Avatar
Old Jul 3, 2003 | 08:58 PM
formularpm's Avatar
Car: '89 Formula
Engine: 355
Axle/Gears: 9 bolt
Leaded fuel will kill your oxygen sensor, and I cant see how it would 'clean' out your gas tank at all. Leaded fuel was designed to slow down valve seat wear, and also to increase the octane of the gasoline, but Ive never heard of it cleaning carbon deposits. The most common cause of excessive carbon is leaky valve seals, which causes buildup on the backs of the valves and loss of power. This is very common on smallblocks. The first thing to do in this case is fix the valve seals. If you are refering to deposits in the tank, its common belief that ethanol will (after long periods of time) break up sludge in your gas tank. Hope this helps...
Old Jul 3, 2003 | 10:08 PM
James Montigny's Avatar
STP makes a pretty little red bottle of deposit cleaner.
Can't go wrong for $.99
Old Jul 4, 2003 | 12:08 AM
Old Jul 4, 2003 | 01:38 AM
25THRSS's Avatar
I wouldn't do it. Just get an ac delco filter.
Old Jul 4, 2003 | 10:59 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
My friend bought an Accel Fuel Filter and we peeled off the Accel sticker and guess what was underneath? It was an AC Delco filter with an Accel Sticker on it. It cost almost $4.00 for that sticker.
Old Jul 5, 2003 | 04:20 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
Best fuel injector is TL3 that stuff works wonders its 3.99 its in a blue bottle. Ive tried every other injector cleaner out there and this by far works the best.
1992 Trans Am
May 10, 2023 07:19 PM
jklein337
Sep 19, 2018 06:23 PM
Infested
May 22, 2018 11:56 PM
Brcharrelson
Aug 26, 2015 07:47 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
