Squeaking Noise
Old Jul 3, 2003 | 10:16 PM
luke7786's Avatar
Squeaking Noise
When I start my car, I have a weird squeaking noise, comming from the front tranny area (flywheel, TQ Converter, etc.). The noise contunies when I am in park, but once I switch gears, into drive or reverse, the squeaking stops. What is the deal with this? PLEASE HELP!
Old Jul 5, 2003 | 09:35 AM
Vader's Avatar
Luke,
A few more questions...
What year / model/ transmission do you have?
Does the noise occur only when cold? Hot? Vary with engine RPM?
Old Jul 5, 2003 | 10:50 AM
Morley's Avatar
Originally posted by Vader
Luke, I am your Father!
Sorry, too rare of an opertunity to pass up.
Check your trans to engine bolts for tightness and drop the inspection plate and check the bolts on the flexplate/flywheel.
Old Jul 5, 2003 | 12:05 PM
Vader's Avatar
I figured that was coming...
Old Jul 5, 2003 | 12:30 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
Old Jul 5, 2003 | 08:18 PM
luke7786's Avatar
My car is a '89 GTA Trans Am with a 350 and auto (no clue as to what number" When I am in gear, it doesnt make noise, but in both park and reverse, it makes this squeaking noise
Old Jul 7, 2003 | 10:32 AM
Vader's Avatar
Noise in PARK or NEUTRAL might be a flexplate, trans oil pump, or intermediate clutch pack problem. Placing the transmission in any gear (forward or reverse) should eliminate the flexplate. Since the noise occurs in reverse but not forward, the pump is probably not an issue, but intermediate clutch pack could still be a problem. If you raise the engine RPM while holding the brake in reverse gear, does the noise still occur or change?
Old Jul 9, 2008 | 08:29 PM
jjlabinski's Avatar
Car: 84 firebird T/A
Engine: shinny 350
Transmission: slush box L65
Axle/Gears: Torsen "3.73"
Re: Squeaking Noise
Vader
Reading this post I have this problem.
I have squeeling noise when I put in reverse and in forward until I give it some gas then it goes away. Noise at all times in reverse no noise in park. This happened after I added fluid.
what could this be?
thx
Jeff
db057
Jan 10, 2020 08:55 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
Nighthawkf-117
Sep 24, 2015 02:47 PM
Randomtask2
Sep 7, 2015 05:06 PM
