I have a question i bet no one can answer!!!!!!
Car: 2008 Jeep Wrangler Unlimited
This isnt a chevy, and its a friends car.
Its a 1991 Lincoln Excutive Series.
And the Ride Control on the Left hand side just flat out dosent work. we have no idea why, do you?
1991 Z28 Camaro L98
5.7 T.P.I. (350)
http://www.bright.net/~rwig/BandetZ28.jpg
http://www.bright.net/~rwig/BandetZ28-2.jpg
1991 Z28 Camaro L98
5.7 T.P.I. (350)
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
Do you hear the pump? it could be leaking and if that is the case I would replace both sides, I seen it happen a few times and ford even say's to do them both, you will fix one and then a weak later the other side will go out.
86Z28, GM 350, Jet perf Q-jet & chip Dual snorkel air cleaner, Edelbrock performer intake, Edelbrock headers, Edelbrock cat-back, Off road pipe, MSD 6AL, Accel Super Coil, Moroso Blue max wires, Rapid fire plugs, Jet fan switch, World class t-5, Hurst Short Throw Shifter, Ram Flywheel, Center force dual friction clutch,Aluminum drive shaft, BW disc rear 3.45's & a posi, PBR calipers, Earls braided brake lines, Polygrapite bushings all the way around, poly tranny mount & torque arm mount, Hotchkis lower control arms & panhard rod, Rancho limiter straps, KYB struts & shocks, Gm Wonderbar, Edelbrock strut tower brace, SSM sub frame connectors, Jamex lowering springs, Carbon metallic brake pads, Crossed drilled rotors, Mobil 1 Tranny fluid & motor oil, GM syntheic rear end oil, K&N, Grant stering wheel, 1,200 watt system, Jet Black Paint, 91 Z28 rims, 92 wing, Tinted windows.
If it's the ride control with the little air bags in the springs, you might have blown one out.
I remember, when I worked at a tranny shop we had to remember to flip the shutoff swith in the trunk or they pump would pop them (or it would just burn out the pump) whenever we put them up on the lift.
Also, there are little plastic "arms" connected to the sensors, sometimes the bushing wears out and they pop off...
If the pump isn't turning on check the switch...
i believe what your referring to is the self-leveling suspension that came on the town cars and continental, correct? if so first inspect the lines going to the left side of the car. if the right side works its not the motor. it could be a broken or crimped line going to the left side of the car. it could also be the diffuser valve that controls which side gets pressure. also there is a sensor that picks up the horizontal level of the car and thats what activates the motor, it could be that its defective and only sending the right side signal. hope this helps.
jptaylor
p.s. my moms got a 97 town car that we spent about a week trying to fix the same problem. it was a dry rotted line that was bleeding pressure
DOH!!!
1989 formula
jasper 350 (punched to 397ci)
trick flow twisted wedge heads
jacobs omni magnum ignition
isky cam
flowtech jethot coated headers
mufflex 4" mandrel stainless exhaust
no cat
holley 670
open element
custom fixed headlights
97 formula interior
macewen white faced gauges
3.42 posi rear end
baer racing 4 piston calipers front and rear
underdrive pullies
hard wired cooling fans http://www.geocities.com/jptaylor2/FIREBIRD.html
[This message has been edited by jptaylor2 (edited October 05, 2000).]
jptaylor
DOH!!!------------------
1989 formula
isky cam
no cat
holley 670
open element
97 formula interior
3.42 posi rear end
underdrive pullies
