L98
Old Oct 4, 2000 | 10:44 PM
CamaroX84's Avatar
L98
Is there ANY difference at all between the Camaro 350 TPI motor and the Trans Am 350 TPI motor? Were they the exact same from year to year? Is the Trans Am 8th VIN digit for the L98 also "8" like in the Camaros? Thanks.
Old Oct 4, 2000 | 10:49 PM
IrocManiac's Avatar
I am not sure about the whole VIN thing. However, everything I have read says the L98 is the exact same from the T/A to the Z-28's. The T/A's have less power because of a more restrictive air intake.
TPI 305,
Gutted airboxes,
gutted MAF,
K&N filters,
Corvette Servo.
14.9@93mph
"Speed kills, wanna live forever, drive a Ford."
Old Oct 6, 2000 | 12:12 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
L98 Firebirds also have an 8 in the 8th digit of the VIN.
The only differences is the intake (it uses a cannister that draws cool air from passenger fender on later models) and the placement of the accessories (a/c, p/s, alt, air pump).
If you cut the sides of the air intake cannister and build a box to enclose the cannister to draw only cool air from the passenger fender, you'll overcome any hp loss.
The "restriction" of the intake track tube from the cannister to the TB flows more air than the TB, so it is not the restriction: only the cannister itself. Cutting the sides out will make the cannister flow more.
Old Oct 6, 2000 | 04:04 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
As far as the blocks go, they are identical. The pontiac engine family was discontinued in 1981( well, im pretty sure it was 81).
1983 Pontiac Firebird SE
LG4-Based Chevy 400
700R4 Tansmission
Modified 4 Barrel Q-Jet Carb
Accel Super Stock 8mm Wires
Edelbrock Pro-Flo Air Cleaner
3.23 Posi Rear
14X7" Cragar SS/T Wheels
35X4 CD/AM/FM Head Unit
100WX2 Amp
2 Pioneer 12" Subs in Custom Box
91chevyz28
Feb 10, 2022 07:58 PM
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
FormulasOnly
Jul 23, 2018 08:47 AM
Tarizza
Sep 24, 2015 12:57 PM
italiano67
Sep 22, 2015 08:42 AM
